7.4 carter AFB carb metering rod springs
Old 05-18-2014, 09:49 AM   #1
Txtruckerpaul's Avatar
My Model: Z240 talari
My Engine: 7.4 bravo III
Send Txtruckerpaul:
Default 7.4 carter AFB carb metering rod springs
Have major problems with flooding and very rich fuel mixture. Took the carb apart and noticed the two metering rod springs are different. Shouldn't these be the same? One takes a lot more effort to compress than the other. I do know that vacuum keeps these rods pulled down into the jets to limit fuel flow, but the springs create resistance against the vacuum pull. I ordered a set of springs and have a color coded assortment of them. What color springs are you carter/weber guys running on your 7.4?
    Metering Rods japatter6181 Mercury MerCruiser 2 09-11-2013 01:45 AM
    what carb is it? coorsmgood Original Mariah Talk 2 08-24-2010 02:18 AM
    What Carb do I have? ggrims Mercury MerCruiser 3 06-12-2010 06:13 PM
    new carb ? boat man2 Original Mariah Talk 4 07-10-2009 06:14 PM
    90 lbs gas springs too much? Billyclub Original Mariah Talk 2 05-13-2009 10:38 PM
    There are 281 users
