Metering Rods
Old 09-10-2013, 11:59 PM   #1
japatter6181 is currently offline
My Model: 190 Shabah
My Engine: 4.3LX Alpha One
Send japatter6181:
Default Metering Rods
What metering rods are people using their Carter/Weber/Edelbrock 4 barrel carburetors on a 4.3LX Vortec engines? I've seen several threads around the internet saying that Vortec engines like to run richer than the standard setup calls for and to go up 2 metering rods. However, I have not seen which rods are "2 up" from the standard setup. There's a lot of metering options to choose from.
Jeff
  • Old 09-11-2013, 12:58 AM   #2
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    Default Re: Metering Rods
    Mine are stock off a fresh carb rebuild, and is almost too rich I think. If you want to go bigger, pull yours out and look at the numbers on them. Take you less than 5 min.
    Old 09-11-2013, 01:45 AM   #3
    Send japatter6181:
    I put the Edelbrock 1485 kit in mine when I rebuilt, so it's running .068x.057 rods with .089" primary and secondary jets.
    Will grinding the first 3" of the trim cylinder piston rods hurt anything? bblauvelt Original Mariah Talk 6 03-18-2008 11:04 AM
    There are 332 users
