Mariah Z260 engine failure on mercruiser 7.4 V8
Old 05-17-2014, 08:01 AM   #1
brianoxo is currently offline
My Model: Z260
My Engine: 7.4L Mercruiser
Send brianoxo:
Default Mariah Z260 engine failure on mercruiser 7.4 V8
Hi, I took my Z260 out for the third time with no problems until I gave the engine a rev up to charge the batteries as they were low next thing I hear a loud click and the engine just died
I have replaced the ecm, fuel pump, injector sensor and map sensor and checked the wiring and relays but no joy can anyone help please
  • Old 05-17-2014, 10:33 AM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Mariah Z260 engine failure on mercruiser 7.4 V8
    Need a little more information. I assume it is the 7.4 MPI and also assume that it cranks but does not fire? Have you put a fuel pressure gage on the rail to make sure it has fuel pressure? Does it have spark? Did you ever determine what the loud click was? Have you done a compression check?
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-17-2014, 02:50 PM   #3
    My Model: Z260
    Send brianoxo:
    it cranks but wont fire and it sparks, fuel pressure is there, but no ground or earthing through the brain to the injectors to let the fuel in
    Power steering line failure JKL Original Mariah Talk 6 03-28-2012 08:15 PM
    Mercruiser 5.0 EFI engine problem timgordon Mercury MerCruiser 4 09-13-2011 01:22 PM
    manual for 4.3 Mercruiser engine removal jbinkley Mercury MerCruiser 1 04-15-2010 04:54 AM
    Engine parts Mercruiser Miami tet68 Original Mariah Talk 1 11-27-2009 02:59 PM
    There are 281 users
