Mercruiser 5.0 EFI engine problem
Old 08-31-2011, 10:08 AM   #1
timgordon's Avatar
timgordon is currently offline
My Model: Z250
My Engine: Mercruiser 5L Alpha I
Send timgordon:
Thumbs down Mercruiser 5.0 EFI engine problem
Hi all,
The other day I got 100 yards from the jetty after the engine started fine, only for it to die and not restart. It has run fine since I have had it (about 5 months). After about 15 minutes the engine did start briefly but failed the moment I went into gear and then refused to restart. After being towed back I started to investigate the issue. The battery is fine. The fuel pump primes when you switch it to ignition 1 and there is fuel in it. The engine turns over fine when you attempt to start but there is no spark or even fuel in the injectors. I have since replaced the coil and the king lead as they looked knackered but I am now thinking it has more to do with a problem with the engine cut off which is preventing a) any spark from the coil and b) any fuel from the injectors. Has anyone ever heard of anything like this?
Many thanks for any advice offered.
Kind regards,
Tim
"Commocean"
2001 Mariah Z250
Mercruiser 5L EFI + Alpha I
  • Old 08-31-2011, 12:08 PM   #2
    olliesmariah's Avatar
    olliesmariah is currently offline
    My Year: 2006
    My Model: sx 18
    My Engine: 4.3 alpha one
    Send olliesmariah:
    Default Re: Mercruiser 5.0 EFI engine problem
    This happened to mine it would start fine then when it got warm it would stop or if you turned it of wouldent start it endedup being a faulty coil .
    Old 08-31-2011, 02:09 PM   #3
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    Just a thought from you have said so far, I would check your safety switch it should cut off fuel and spark to the engine if it is accidentally being activated.
    darkcalling
    Z 278 Limited
    Old 09-13-2011, 09:00 AM   #4
    timgordon's Avatar
    My Model: Z250
    Send timgordon:
    Hi guys, thanks for your responses. The issue has now been resolved and I thought I would let you know what it was. It was the optical sensor unit within the distributor. The rotor arm looked like it had been vibrating the sensor unit and a tiny microchip had fallen off the sensor unit causing it to fail and not report to the ECU the rotor position. The ECU in turn then would not send a message to the injectors to fire. The new sensor unit cost about £150. Looks like Mercruiser had noticed this flaw as the new unit had the electronics embedded in a resin. Anyway all good now, just waiting on some good weather in the UK. Kind regards,
    Tim
    "Commocean"
    2001 Mariah Z250
    Old 09-13-2011, 01:22 PM   #5
    I would have never guessed....
    cut off , efi , mercruiser , not starting
    mercruiser 5.7 problem Brownboy Boating 101 3 10-13-2010 04:03 AM
    manual for 4.3 Mercruiser engine removal jbinkley Mercury MerCruiser 1 04-15-2010 04:54 AM
    Engine parts Mercruiser Miami tet68 Original Mariah Talk 1 11-27-2009 02:59 PM
    There are 318 users
