Air/fuel adjustment
Old 04-12-2014, 06:13 PM   #1
Juskol18 is currently offline
My Model: 202 shabah
My Engine: 5.7 alpha one
Send Juskol18:
Default Air/fuel adjustment
Took the boat out yesterday and it seemed alittle sluggish so I pulled the plugs when I got home and they are light brown, with a little white on tip of electrode. This sound normal or should I adjust to run more rich? If so how do I go about doing this? Boat is shabah 202 w/ merc 5.7l carb [/IMG]ImageUploadedByTapatalk1397326268.216813.jpg
Thank you Juskol18 for this useful post!
Bill (04-13-2014)
  • Old 07-09-2014, 02:31 PM   #2
    Send Juskol18:
    Default Re: Air/fuel adjustment
    bump! anyone??
    Old 07-09-2014, 02:52 PM   #3
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Juskol,
    Brown/white usually indicates a proper firing plug. If the sluggishness is only on acceleration then I would look else where...is your accelerator pump functioning properly?
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 07-09-2014, 06:19 PM   #4
    Originally Posted by Hudson River Steve View Post
    Juskol,
    x2 on Steve's comments.
    Old 07-12-2014, 03:14 AM   #5
    TMRoper1669 is currently offline
    Send TMRoper1669:
    I agree with mikeyt, sounds like an accelerator pump issue to me. The easy way to test the accelerator pump is to take everything off the top of the carb (like you have in your picture,) make sure your carb is full of fuel (Has ran recently but not running), have someone else accelerate the throttle quickly while you look into the carb. You should see a good stream of fuel into the carb, don't do this more than twice or you could flood your motor. If is shoots a good stream then your accelerator pump is most likely working properly. The next thing you could do is take the top of the carb apart and check if you have a float sticking. I recently went through a similar problem and turned out to be a sticking float. Hope this helps.
    SX19 4.3 hard start then no start after cable adjustment Lucky14 Sea Fox - Mariah Talk 3 08-22-2013 11:54 AM
    Neutral adjustment issue Lewy Mercury MerCruiser 1 06-23-2013 09:32 PM
    Throttle Cable Adjustment??? berk1402 Mercury MerCruiser 0 07-06-2010 03:51 AM
    Docking light adjustment? ckgreenman General Maintenance 10 07-10-2009 10:09 PM
    Carb Adjustment 1992 Mariah 4.3 Litre seapoo Original Mariah Talk 6 07-01-2009 09:38 PM
    There are 276 users
