Coil wiring 98 Mercruiser 4.3 Thunderbolt Ign
Old 08-26-2013, 10:28 PM   #1
Mark from Long Lake is currently offline
My Model: 1997 Shabah 186, Mercury 4.3
Send Mark from Long Lake:
Default Coil wiring 98 Mercruiser 4.3 Thunderbolt Ign
I had to replace the coil on my 1998 4.3 Thumderbolt, I lost the diagram I drew of the coil.
There are 3 wires, it seems like:
Black to -
purple +
Does the gray go to + or -?
Mark
  • Old 08-26-2013, 11:34 PM   #2
    Default Re: Coil wiring 98 Mercruiser 4.3 Thunderbolt Ign
    Gray goes to tach signal. Negative side of coil.
    Old 08-26-2013, 11:39 PM   #3
    Thanks, I thought so but couldn't remember to save my life!
    Old 08-28-2013, 12:23 AM   #4
    Default It still won't start.
    I replaced the coil which was rusty on the back side and the ignition wires. The fuel pump is functioning and there is fuel to the carb. I bypassed the "kill Switch".
    I don't think it has spark. What should I check next?
    Old 08-28-2013, 12:25 AM   #5
    The engine serial number is 0L037602
    1998 Mercruiser 4.3 with Thunderbolt Ignition
    Old 08-28-2013, 12:56 AM   #6
    Did you make use of our Starting Troubleshooter Sticky??
    Old 08-31-2013, 03:10 AM   #7
    Default No Spark
    I went through the Starter Trouble Shooting as Mikey suggested just to be sure. Everything is working ignition switch, neutral start swith, slave solenoid, starter, fuel pump. But there is no spark. I replaced the coil, there is power to the coil, but no out put. Is there a way to test the new coil? Is there an ignition wiring diagram...is it possible the replacement coil is bad?
    Mark
    Old 08-31-2013, 03:15 AM   #8
    Do you have power to the coil while cranking?
    Old 08-31-2013, 03:45 AM   #9
    Yes to the positive side of the coil and the ground is good.
    Old 08-31-2013, 02:58 PM   #10
    Faulty coil or Ignition Control Module it sounds like.
    What voltage do you have at the coil? Should be 5-8 volts going in if I remember right.
    Use a multimeter:
    You can test the primary circuit(power in) , it should be between .6-.8 ohms.
    Secondary circuit(high voltage terminal) should ohm out between 9.40-11.70 ohms.
    If out of range the coil is bad , if within limits , Merc manual says to replace Ignition Control Module.
    1998 Mercruiser 4.3L Thunderbolt V Fuel Sending Unit. not functioning Mark from Long Lake Mercury MerCruiser 3 05-20-2013 09:46 PM
    mercruiser 350 wiring harness pokes Mercury MerCruiser 9 03-13-2013 08:58 PM
    coil polarity on a 1997 Shabah w/4.3 zrx Mercury MerCruiser 4 08-26-2012 02:39 AM
    Anyone convert the Thunderbolt ignition to an EST elimont Original Mariah Talk 0 10-09-2010 08:45 PM
    93 5.0 LX Thunderbolt Alpha 1 Horsepower Snowaterdude Original Mariah Talk 7 09-30-2009 12:21 AM
    There are 363 users
