Starting delay then turns over
Old 08-04-2013, 09:37 PM   #1
mariahsx20 is currently offline
My Year: 2006
My Model: SX20
My Engine: 5.0L MPI
Send mariahsx20:
Default Starting delay then turns over
This summer, I have had a hard time getting my 5.0L MPi to start. I replaced the batteries and clean all the connections. Typically after a week of sitting we put her in the water, I get nothing when I try to start. I wait a couple of minutes and the starter will click after holding the key a few seconds. After a couple more tries she will click while holding the key and then turn over. After she is warmed up and we stop at a cove. When I restart her I get nothing for a few seconds and then she will turn over and every time after that there is a few sec delay and then she turns over. At one time I thought it might be the Perko Battery switch because I would wiggle the battery cables and she would start but I check and clean all the connections.
Any ideals on where to check connections and voltages before I bring he to the mechanic.
Steve
  • Old 08-04-2013, 11:39 PM   #2
    Default Re: Starting delay then turns over
    I'd make sure I didn't have a voltage drop from the battery to the starter , ignition switch to solenoid.
    Did you clean the main plug connection that goes to the cockpit?
    Have you tried jumping the solenoid when this occurs? Could just be a bad ignition switch too.
    How about wiggling the shifter when trying to start? Neutral Safety Switch could be out of adjustment also.
    Just a few things to look at/think about.
    Old 09-02-2013, 12:40 AM   #3
    My Year: 2006
    My Model: SX20
    My Engine: 5.0L MPI
    Send mariahsx20:
    Thanks for the response. I tried all the basic stuff, so I bought a replacement slave solenoid because it was easy to reach and replace for under $15 dollars. I no longer have silence. but the now the starter will just click. I couldn't reach it to check the solenoid but if I turn the ignition key in rapid concession this will eventually get the starter to turn-over. The engine fires right up. I had to do this early in the day but by the end of the day it will start fine. I am assuming I have a bad starter. So the question is should I do a replace it with a new one or rebuilt ? & factory or OEM starter. Is there a brand I need to stay away from. Finally is this a do it yourself or Mechanic required aka any special keying or procedure before you can install the new starter.
    starting Brad97 Original Mariah Talk 5 01-01-2013 05:05 PM
    Hard starting 4.3LX mx20 Original Mariah Talk 3 10-06-2011 11:09 AM
    Anyone added a Time delay relay to their Alarm buzzer scubydo Original Mariah Talk 2 08-31-2010 12:25 PM
    Not always starting Snowaterdude Original Mariah Talk 1 09-20-2009 03:31 AM
    starting issues murphysocc Mercury MerCruiser 2 07-13-2009 06:36 PM
    There are 329 users
