Coil wiring 98 Mercruiser 4.3 Thunderbolt Ign
Old 08-31-2013, 03:32 PM   #11
Mark from Long Lake is currently offline
My Model: 1997 Shabah 186, Mercury 4.3
Send Mark from Long Lake:
Default Re: Coil wiring 98 Mercruiser 4.3 Thunderbolt Ign
Thanks Larry, I wanted to suspect the engine control module...but only because I know the least about it. I'm going to head down to me dock with my multimeter.
Which is the high vs. low?
  • Old 08-31-2013, 03:40 PM   #12
    High is coil output , low is power into coil.
    Good Luck
    Old 08-31-2013, 04:06 PM   #13
    Thanks!!!! I'm on it!
    Old 09-02-2013, 12:11 AM   #14
    Ok Larry, it looks like it's the Ignition Control Module, mine is Denso manufactored. If I order it from Mercuriser it is nearly $600. Do you know of any Denso or GM applications that will work?
    Mark
    Old 09-02-2013, 01:00 AM   #15
    New - ICM 458.00.
    Used - probably Ebay too.
    Old 09-02-2013, 01:47 AM   #16
    Thanks Larry. The number on mine is 861251-1. Does the 861251T1 supercede the one on mine? My engine serial # is 0L037602.
    1998 Mercruiser 4.3L Thunderbolt V Fuel Sending Unit. not functioning Mark from Long Lake Mercury MerCruiser 3 05-20-2013 09:46 PM
    mercruiser 350 wiring harness pokes Mercury MerCruiser 9 03-13-2013 08:58 PM
    coil polarity on a 1997 Shabah w/4.3 zrx Mercury MerCruiser 4 08-26-2012 02:39 AM
    Anyone convert the Thunderbolt ignition to an EST elimont Original Mariah Talk 0 10-09-2010 08:45 PM
    93 5.0 LX Thunderbolt Alpha 1 Horsepower Snowaterdude Original Mariah Talk 7 09-30-2009 12:21 AM
    There are 252 users
