2000 183 Shabah Not Starting
Old 08-06-2013, 04:07 PM   #1
Doc Thread Starter
Doc is currently offline
My Model: Shabah 183
My Engine: 4.3 Merc
Send Doc:
Default 2000 183 Shabah Not Starting
I have a 2000 183 shabah that won't start. It turns over, but does not start.
1) I recall that I should hear the fuel pump for a bit when I first turn the key on. Is this correct? Currently I do not hear it.
2) I can not seem to get at the schematics on this site. Are they not available for a reason?
3) Does anybody have a set of schematics for this boat?
Thanks in advance for any help.
  • Old 08-06-2013, 04:56 PM   #2
    Default Re: 2000 183 Shabah Not Starting
    Doc ,
    Sent you a email per your "contact us" post.
    Those materials are only available to contributing members.
    And yes you should hear the fuel pump "prime" for the first second or two.
    I'd check to make sure you have power at the pump.
    Did you check your fuses/breakers?
    Get a can of non chlorinated brake cleaner , spray into intake/carb and see if it will fire on it.
    If it does , definitely a fuel issue.
    Old 08-06-2013, 05:45 PM   #3
    luke7575 is currently offline
    My Model: z302 Shaba
    My Engine: 7.4l Volvo Penta Duop
    Send luke7575:
    If u have a kill switch check make sure its still good they do go out, its happened on my jetski
    2000 Shabah 212 robdow808 Mariah Boats For Sale & Wanted 2 06-30-2011 02:08 AM
    2000 258 Shabah, cold starting dvanluit Original Mariah Talk 8 08-15-2009 08:44 PM
    2000 Shabah dweissma Mariah Boats For Sale & Wanted 2 07-19-2008 12:12 AM
    2000 212 Shabah dhughes Introductions 2 10-22-2007 06:45 AM
    2000 182 Shabah donnae Original Mariah Talk 4 08-22-2007 11:05 AM
    There are 240 users
