Rebuild or replace engine?
Old 06-21-2011, 06:04 PM   #1
csterner's Avatar
csterner is currently offline
My Model: Z275ST Shabah
My Engine: 6.2L Bravo III
Gallery Images: 9
Send csterner:
Default Rebuild or replace engine?
So after pulling my risers and seeing the level of corrosion, I will have to replace my manifolds, risers, and backflow preventer. The parts alone are a little over $1,000. So if I do replace them, I know that I will probably have more issues soon thereafter. So I am thinking to save up and replace the engine. Would it be better to rebuild the existing engine so the serials match? Or would it be better to go with a 383 stroker? I do like the idea of more HP, but I do not have alot of money right now. I have seen online that I can pick up a rebuilt 383 for just under $3,000. Any advice would be greatly appreciated...
2001 Shabah Z275 ST
6.2L Merc with Bravo III
  • Old 06-21-2011, 07:42 PM   #2
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    Default Re: Rebuild or replace engine?
    If you trust the builder thats not a bad idea any warranty with it? According to some research I did and I research the crap out of things the stories of higher nickle content in marine blocks is not true so a good build wether auto or marine will work its your maintenance that keeps it running great and reliably if that helps. I forget did you say it was in salt water or you are still in salt water?
    darkcalling
    Z 278 Limited
    Old 06-21-2011, 07:48 PM   #3
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    The original owner was 100% salt water usage. I run about 70-80% fresh water and the rest salt water. And unlike the original owner, I am pretty religious about flushing the motor out!
    2001 Shabah Z275 ST
    Old 06-21-2011, 07:57 PM   #4
    Gallery Images: 3
    Send darkcalling:
    Just a thought here then not sure though you could probably find one of those ZZ crate all alum small blocks and I ran alum manifolds and risers on mine shaved off alot of weight on my old boat but if your in a fair bit of salt I hear alum not so great.
    darkcalling
    Z 278 Limited
    Old 06-21-2011, 08:00 PM   #5
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    Yea, I have always been told the same thing that if you run salt alot that you need to stay away from aluminum. I hear it corrodes faster than cast iron or something.
    2001 Shabah Z275 ST
    Old 06-21-2011, 08:04 PM   #6
    Gallery Images: 3
    Send darkcalling:
    Yeah maybe one of our more experienced memebers can add but I run only fresh so it was perfect for me up here I think it shaved 44olbs off the boat in there somewhere would have to see if I have the scale slips before and after still.
    darkcalling
    Z 278 Limited
    Old 06-21-2011, 11:54 PM   #7
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    If you are in salt at all, you should budget for a closed cooling system. There is no way i would do all that work and run salt water through the block again. No matter how well you rinse after use, you will be much better off protecting the block and manifolds with fresh water coolant and then all you worry about replacing is your risers.
    I am in salt 50% and have always rinsed after use even with a closed cooling system.
    I think the difference in auto vs marine is the rotation, left hand or right, and there are intake differences and some ignition differences, I dont think you can do a clean auto engine replacement even though it seems like you save a bunch it will bite ya in the end. I am no engine expert, but I say "Go marine".
    Zack
    1994 Z212 Shabah
    Old 06-21-2011, 11:58 PM   #8
    rooperdan's Avatar
    rooperdan is currently offline
    My Model: 1998 SHABAH 210
    My Engine: Built 350 Alpha Drive
    Gallery Images: 10
    Send rooperdan:
    I had my 350 built to a 383 stroker and LOVE it. Great torque and good top end speed, best of both worlds.
    Quietly Making Noise
    Old 06-22-2011, 12:22 AM   #9
    Gallery Images: 3
    Send darkcalling:
    I built my old 5.7 up out of a 4 bolt main street engine, same build I have used in countless cars and its been super reliable and no prob but I don't see salt water with it or I never did see salt water with it. But I would agree with a closed system if you see salt and hey Zack has probably been boating longer then me the land locked guy lol.
    darkcalling
    Z 278 Limited
    Old 06-22-2011, 02:00 AM   #10
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    I agree, I will always go marine. No reason to chance that. About this closed cooling system, not sure about those. Don't you have to add a radiator or some type of cooling system? Not sure if its worth it to do all that though. one of my friends has a cruiser that he has had for 11 years, and he is just now replacing his engine and he runs as much if not more salt water than me. I agree that salt is bad. I guess if I can do the cooling system easily enough, then maybe I should. If I do, then I would feel alot more comfortable about getting an aluminum engine instead! Yea!!!!!
    2001 Shabah Z275 ST
    Thank you csterner for this useful post!
    Mariah350 (07-01-2011)
    Carb Rebuild How to? dakotaman728 Mercury MerCruiser 3 08-08-2011 12:58 AM
    need to pull engine to replace Y ring, need help corko Introductions 1 05-09-2011 01:21 AM
    need to replace console peddlerman2001 Introductions 0 08-06-2010 09:16 PM
    rebuild 95 barchetta SCOTT Introductions 2 07-13-2009 10:44 PM
    Remove and Rebuild 4.3 Mec sirbb Mercury MerCruiser 1 04-05-2009 12:58 PM
    There are 223 users
