Cracked intake manifold, Help.
Old 05-18-2013, 04:10 PM   #1
chevybar is currently offline
My Model: z190 talari
My Engine: 4.e Mercruiser
Send chevybar:
Default Cracked intake manifold, Help.
Hello everyone! Just finished installing new long block 4.3 in the boat, put water to it to check for leaks and regretfully found the intake to be cracked, got to love this stuff. The 4bbl 12 bolt on the '95 is almost impossible to find, new or used, maybe someone can tell me where to find one or should I go with a new Edelbrock and be done with the Mercruiser intake. I'll have to change my chock to electric but that is not an issue, Thanks in advance!
  • Old 05-18-2013, 11:45 PM   #2
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    Default Re: Cracked intake manifold, Help.
    I'd buy an aluminum one and be done with it. Are you sure none of them will accommodate a manual choke?
    Old 05-18-2013, 11:57 PM   #3
    Send chevybar:
    I sure that some do, my carb has a heat riser to operate choke, I figured it was a good time to change. I have looked everywhere at new manifolds, one place says the Edelbrock Performer will not work with the balance shaft 4.3, others do not know, I am going to call Edelbrock monday when someone is there with a little more knowledge, Thanks. Open for suggestions.
    Intake leak???? njc15880 Mercury MerCruiser 17 07-02-2013 07:57 PM
    Oil Leak From Water Intake Slash9point5 Mercury MerCruiser 4 08-15-2011 02:28 PM
    where is fresh water intake on 6.2L? csterner Mercury MerCruiser 1 04-21-2011 12:40 AM
    v6 12 bolt intake to v6 8 bolt intake motor SCOTT Original Mariah Talk 3 07-21-2009 01:30 AM
    Intake full of sand/mud - overheat cleah Mercury MerCruiser 2 09-19-2008 01:33 PM
    There are 377 users
