Constant beeping....
Old 05-14-2013, 07:21 PM   #11
Default Re: Constant beeping....
I had the boat out this weekend. Runs great but with the oil res in plugged it still beeps intermittently. I asked a guy at the lake an he seemed to think there are different beeps for the different alarms like solid for oil an temp issues. Have not confirmed that.
Another suggestion was to connect the two ends I unplugged from the oil res. I just have them out of the way.
With it unhooked I'm curious if it could be a temp sensor seeing as the beeping starts at higher rpm. Does the 7.4 have two temp sensors? One for the gauge an one for the alarm?
  • Old 05-14-2013, 08:08 PM   #12
    Have you checked the float switch in the gear lube reservoir? Found this while doing a site search for "Alarms"
    Old 05-14-2013, 09:10 PM   #13
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    Did you clean that oil float in the tank? And I am not sure about the 7.4 but I know that my 6.8 has 2 temp sensors. One on either side of the thermostat housing.
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Old 05-14-2013, 10:28 PM   #14
    Thanks Mikey, I have recently cleaned the air filter. It was not too bad. That was when I got the boat back in Feb.
    As for cleaning the res, I also did that when rebuilding the outdrive prior to filling with fresh oil.
    I'm starting to lean towards the temperature alarm sensor. As in the sensor is faulty. I will make sure it even has one on mercruiserparts.com
    Old 05-15-2013, 11:49 PM   #15
    While snooping around last night I found a pretty cool PDF about the codes. I had been looking through the Mercruiser literature and could not come up with answers for my questions. Might make a good sticky!
    Beep codes
    woodward33 and ColoradoDiablo like this.
    Thank you Motoxxx43 for this useful post!
    woodward33 (05-16-2013)
    Old 05-15-2013, 11:59 PM   #16
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    Great find
    2000 Z302 Bow Rider
    Old 05-16-2013, 02:33 AM   #17
    Beep codes
    Absolutely. Done!
    Old 05-16-2013, 01:36 PM   #18
    Nice find Moto!!
    Old 05-16-2013, 05:09 PM   #19
    woodward33's Avatar
    woodward33 is currently offline
    My Model: Z302 Shaban
    My Engine: 502 Bravo III
    Send woodward33:
    Great find. Thanks so much.
    Beeping alarm - Unknown cause driew Original Mariah Talk 3 08-18-2010 09:27 AM
    Beeping Noise??? llcelebrity Original Mariah Talk 3 08-13-2009 04:34 AM
    Warning Alarm Beeping Every 4 seconds ShabahZ280 Mercury MerCruiser 8 11-05-2008 03:35 PM
    There are 364 users
