Merc Bravo III Problem
Old 08-09-2012, 11:21 PM   #1
1621Mariah is currently offline
My Model: Shabah
My Engine: 7.4L BravoIII
Send 1621Mariah:
Default Merc Bravo III Problem
Any insight into the possible problem would be appreciated before I tear the drive apart. The problem, my Bravo III outdrive is now starting to have problems with what I am calling a " sliipage"
By that I mean, when I start to apply the throttle the motor rpm and speed to not react accordingly. The outdrive starts to make a "grumbling noise" The motor rpm will increase with no speed to the boat. I apply more throttle, going from aprox. 1k rpm up to 2krpm and the boat does not move like it has, should. The motor rpm will quickly jump up to 2500-2700 rpm without the boat speed increasing. At low rpm 1K rpm and lass it seems to operate okay. No problem in going from F/N/R . The shift is definite. Just at a RPM above 2K I see the problem. Plus I find this problem happens when the motor/outdrive gets up to operating temp,aprox 175F. When it is cold, I pull out of the harbor it works as it should, comes on plane. All fluids are full. Any answers , tests,or solutions. Appreciate your help!
  • Old 08-13-2012, 12:23 AM   #2
    Default Re: Merc Bravo III Problem
    Check the hubs (or get a prop guy to check them) in your props before you start tearing your drive apart.....
    Old 08-13-2012, 02:05 AM   #3
    My Model: Shabah
    Send 1621Mariah:
    Thanks mikeyt, I will do that. Its coming out of the water next weekend. I will drain the outdrive fluid and make sure no water has made its way in. It has been slipped for the last two months, great having it available when ever you want to go but hope I didn't intoduce water into the drive.
    Old 08-15-2012, 12:35 AM   #4
    wplaine's Avatar
    wplaine is currently offline
    My Model: Z215 Talari
    My Engine: 5.7L Bravo III
    Gallery Images: 15
    Send wplaine:
    Keep us posted. That is a new one i havent heard about or experienced.
    Walter in VA
    '96 Talari Z215
    350 Merc/Bravo III
    Old 08-16-2012, 12:17 AM   #5
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Years ago I had a motor coupler that failed and slipped as you described.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-27-2012, 11:26 PM   #6
    My Model: Shabah
    Send 1621Mariah:
    Hudson River Steve
    Thanks, I am pretty sure that is what is the problem. Big problem.!
    Merc I/O - what goes down won't come up ATX_Diablo Mercury MerCruiser 8 07-11-2012 06:15 PM
    3.0 Merc alternator install help... Wakeboarder5272 Mercury MerCruiser 5 08-12-2011 02:21 PM
    6.2L Merc with starter issue csterner Mercury MerCruiser 9 05-30-2011 01:37 PM
    Oil for my Merc 350 Jbetschart Original Mariah Talk 1 03-14-2010 09:43 PM
    There are 408 users
