6.2L Merc with starter issue
Old 05-18-2011, 11:11 PM   #1
csterner's Avatar
csterner is currently offline
My Model: Z275ST Shabah
My Engine: 6.2L Bravo III
Gallery Images: 9
Send csterner:
Default 6.2L Merc with starter issue
First let me say that I have read the sticky thread on starter issues. But let me give you some background...
I just bought this boat a little over a month ago. We ran it 4 times in fresh water and no issues whatsoever. The last time we took it out, it started overheating as soon as we left the dock. I immediatley turned back around and shut her down. Once I got her home, I realized that the impeller had disintegrated. There was nothing left but the rubber shaft! So I replaced the impeller and the whole water pump housing. I wasn't able to test run her on land because my intake is on the bottom of the hull and I can't get a flusher under my trailer. So I took her back out to the lake to see if the impeller worked. When I turned the key, I got a very loud almost metal sounding bang, and the engine did not turn. I freaked out and thought the engine had seized up. So I took it to someone who looked at it and hit something back by the starter and the engine did bump over a little. We found that terminal A on the starter solenoid had disintegrated and the rubber boot over it was melted. I replaced the connector and tried to bump the engine and get nothing now. No click or anything.
So this is what I get following the sticky starter thread: I get voltage on Terminal A of the slave solenoid with the ignition switch off. As soon as I put the key in Accessory position, the voltage disappeared. I got no voltage on A, B, C, or D of the slave solenoid. UUUGGGGGHHHHH
I have tried to remove the ground wires on the grounding buss bar to clean them but they are frozen on there! So I am soaking them overnight in JB Blaster and will try tomorrow to remove and clean them. I am just hoping that after all this that my engine will actually crank and isn't toast!!!
Anyways, any help would be greatly appreciated....
2001 Shabah Z275 ST
6.2L Merc with Bravo III
  • Old 05-19-2011, 04:01 PM   #2
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    Default Re: 6.2L Merc with starter issue
    I am such a freakin' idiot. After cleaning the ground buss bar in the engine compartment there was still no change. Long story short...It turned out to be a dirty terminal on the ignition switch. I cleaned them all up and the engine bumped over! Yea! Now I just need to get my Flush Pro system so I can start her all the way up on land.
    2001 Shabah Z275 ST
    Old 05-19-2011, 07:18 PM   #3
    Zackattack's Avatar
    My Engine: 5.7 Alpha 1
    Send Zackattack:
    Very glad to hear the good news.
    Zack
    1994 Z212 Shabah
    Old 05-20-2011, 10:02 PM   #4
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    The saga continues...So I installed my homemade flush valve( I didn't want to fork out $68 for the Flush Pro system) on my raw water intake today and was so excited to try and fully start her up on land. So when I turned the key it sounded like the engine was turning over, but it was a loud metal sound. It was like the starter wasn't grabbing. So I am assuming that my starter or flywheel is shot. Is this a correct assumption? I will pull the starter tomorrow and see what it looks like. And any tricks to pulling the starter?
    2001 Shabah Z275 ST
    Old 05-20-2011, 11:29 PM   #5
    Zackattack's Avatar
    Send Zackattack:
    Just a note, make sure voltage is high on the batteries. Its possible for the starter to not operate correctly with insufficient voltage I believe.
    Zack
    1994 Z212 Shabah
    Old 05-20-2011, 11:45 PM   #6
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    Yea, my batteries are fully charged. I keep it plugged into my trickle charger with shore power at my house. Is there a way to check the flywheel when I pull the starter? I hate to destroy a new starter because it turns out the flywheel is chewed up!
    2001 Shabah Z275 ST
    Old 05-21-2011, 10:10 AM   #7
    il_Mio's Avatar
    il_Mio is currently offline
    My Year: 2008
    My Model: SX18
    My Engine: 3.0L TKS - Alpha I
    Send il_Mio:
    Maybe also check if not in gear whilst starting.
    Succes,
    Johan
    Old 05-21-2011, 03:48 PM   #8
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    Ok, got the starter out. I posted some pics of it. Is it possible to rebuild this or should I just chunk out the $214 for a new one....
    2001 Shabah Z275 ST
    Old 05-22-2011, 01:08 AM   #9
    Zackattack's Avatar
    Send Zackattack:
    I vote go new, I am all for saving a buck but not on the starter. And only buy the marine starter, they are not the same as auto parts starters as you are likely aware.
    Zack
    1994 Z212 Shabah
    Old 05-30-2011, 01:37 PM   #10
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    Brand new starter installed and she fired right up! Love it!!!
    2001 Shabah Z275 ST
    Starter Issue ginodesico General Maintenance 2 09-27-2010 03:23 AM
    Starter huntnfish Mercury MerCruiser 6 07-25-2010 04:41 PM
    Oil for my Merc 350 Jbetschart Original Mariah Talk 1 03-14-2010 09:43 PM
    Merc 5.7 freeze plugs dlowings Mercury MerCruiser 2 01-28-2010 12:05 AM
    Bad starter? Dogloop Mercury MerCruiser 9 07-03-2009 09:20 PM
    There are 374 users
