Ignition Problem
Old 06-10-2012, 03:11 AM   #1
Griffin32 is currently offline
My Year: 2006
My Model: SX18
My Engine: 3.0 / Alpha I
Send Griffin32:
Unhappy Ignition Problem
Hi everyone. I hope everyone is having a better weekend than I am. I just got back from being towed off of the lake. I'm not sure what my issue is but I figured this would be a good place to inquire.
I have a 2008 SX18. I was buzzing around on the lake all day long and decided to stop at a gathering spot where a lot of boats hook up and people just hang out. Not 20 minutes after I got there I decided to leave. When I turned the key - NOTHING! No alarm - no movement on any of
the guages - nothing. The radio the trim and the depth finder all still work but thats it. The battery is brand new but I'm going to have it tested tomorrow anyways.
The kill swith is in the run position and the trans is in nuetral. I did try to shift from gear back to nuetral a few times.
Any ideas Thanks a lot everyone. i really appreciate it!
  • Old 06-10-2012, 10:35 PM   #2
    My Year: 2006
    My Model: SX18
    Send Griffin32:
    Default Re: Ignition Problem
    Battery checked out....
    any suggestions?
    Old 06-11-2012, 05:07 PM   #3
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    It sounds like a bad connection somewhere or a bad ignition switch. Do you have one or 2 batteries? Do you have a battery disconnect switch? How handy are you with checking electrical connections? Do you have a 12volt test light? I would start with the big cables coming from the battery. If they are tight and CLEAN it is a matter of following where they go and checking the cleanliness/tightness and voltage at each connection point. You could also check the voltage at the ignition switch pretty easily. Hope this gives you a starting point.
    Good Luck
    Dan
    1995 Z272 Barchetta
    Old 06-13-2012, 06:26 PM   #4
    paulcj77's Avatar
    paulcj77 is currently offline
    My Model: 180 shaba ltd
    My Engine: 2012 merc 4.3 mpi
    Send paulcj77:
    I had same problem on my 97 180 Shaba turned out to be
    The main wireing connector where it plugs in to the engine
    Loom.
    Give it a wiggle that's how I found mine!
    Regards
    Paul
    Old 06-14-2012, 09:22 PM   #5
    jeffreyb is currently offline
    My Model: 1900Z
    My Engine: 4.3LXI Alpha1 Gen2
    Send jeffreyb:
    Smile Re: Ignition Problem
    I have this problem occasionaly and its always the ignition switch I just reach under the dash and move or wiggle the wires around and it starts. It seems like I have to replace it every couple years, maybe that's your problem not sure hope it works good luck!
    Wanted: Ignition module wes3337684 Mariah Parts For Sale & Wanted 2 04-03-2012 01:06 AM
    Problem with Ignition Switch lmdengler Original Mariah Talk 3 05-31-2011 12:43 AM
    Ignition? inertia Introductions 0 08-02-2010 08:19 PM
    Squealing ignition kender Introductions 3 07-04-2010 05:14 PM
    Ignition switch Provo Original Mariah Talk 1 08-15-2009 09:21 PM
    There are 359 users
