Squealing ignition
Introductions
Old 07-03-2010, 03:49 PM   #1
kender is currently offline
My Model: Jubilee 204
My Engine: 4.3 liter mercruiser
Send kender:
Default Squealing ignition
Normally on our 1998 Mariah 204, when turning the ignition key, a high pitched squeal happens for a couple of seconds until the engine is started. Now, that squeal will not stop. Any ideas?
  • Old 07-03-2010, 05:13 PM   #2
    Default Re: Squealing ignition
    Could be a belt, could be a number of things. Where is the squealing coming from on the engine? If its possibly a belt, you could just rub a bar of soap on the inside of the belt to see if it stops. If so, you need a new belt.
    Old 07-04-2010, 03:20 AM   #3
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    I wonder... There is a warning alarm for over-temp, low oil pressure and low gear lube. There is usually a delay that keeps it from going off for about 20 seconds or so after the key has first been turned on, to give the oil pressure time to come up. But I believe I've heard cases where, for whatever reason, there was no delay and it would come on right away--and until the oil pressure came up.
    Could that be what you're hearing? Does it sound like it's coming from behind the instrument panel at the helm?
    If that's what it is, now it won't shut off, and you're engine temp and oil pressure are good, you may have low gear lube. Or you may have a bad sensor.
    Jim
    Old 07-04-2010, 05:14 PM   #4
    Kinda hard to diagnose with such limited information. But if i remember the movie 'Deliverance', one man's squealing is another man's alarm......
    « Hello | 1995 2350z »
    Squealing from engine buddyboy Mercury MerCruiser 2 07-03-2010 10:29 AM
    Mariah keypad ignition? BobZ270 Original Mariah Talk 1 12-30-2009 09:52 PM
    Possible Ignition Problems?? Help! jeffryb Original Mariah Talk 3 09-18-2009 12:28 AM
    Ignition switch Provo Original Mariah Talk 1 08-15-2009 09:21 PM
    There are 363 users
