New transom assembly now trim up not working
Old 03-17-2011, 10:51 PM   #1
grommett's Avatar
grommett is currently offline
My Model: Z202 Shabah
My Engine: 350 Magnum 5.7L Alpha
Gallery Images: 10
Send grommett:
Default New transom assembly now trim up not working
Hi, getting ready for start of season and really looking forward to it.
I had excess play in the steering so I had my mercruiser dealer replace the complete transom assembly (and new engine mounts while it was out). I got a call saying it is ready for collection but did I know the trim up button doesnt work (the trailer button does still work though). Actually I never had a problem with it before so I am wondering if it could be something at the transom end rather than the control/button end. I'd be greatful for any knowledge before I collect on Saturday.
Cheers, Grommett.
  • Old 03-18-2011, 03:53 PM   #2
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Default Re: New transom assembly now trim up not working
    Sounds like the trim limit sensor just needs adjusted or maybe replaced. It just thinks it's already trimmed all the way up.
    http://www.sterndrives.com/replacing_trim_senders2.html
    Old 03-18-2011, 05:20 PM   #3
    grommett's Avatar
    Gallery Images: 10
    Send grommett:
    Hi Dredd
    The whole transom assembly has been replaced including RAM,s gimbal etc, I imagined this would include new senders? In which case it must be adjustment that the engineers should have done.
    Old 03-18-2011, 06:51 PM   #4
    Dredd's Avatar
    Send Dredd:
    Yeah, it would seem odd/cheap if they didn't replace those when everything was apart because they do wear out and replacing them is a chore. It also seems odd that a shop capable of doing all that work doesn't just diagnose the issue for you since you just paid them a nice chunk of change.
    If they were replaced then the first thing I'd check would be the switch.
    Old 03-26-2011, 08:19 AM   #5
    ridnwild is currently offline
    My Engine: 5.7 bravo III
    Send ridnwild:
    I know you know this but I didn't and maybe other new owners don't.
    I thought my trim up switch was not working but I found out that it works fine. With the drive down it will only bring it up to ½ on the trim gauge to keep you from over trimming after that you have to use the trailer button to finish raising it all the way up.
    Old 03-26-2011, 06:30 PM   #6
    grommett's Avatar
    Gallery Images: 10
    Send grommett:
    I got a call from the workshop on tuesday to say the fault had been rectified, something to do with a wire. So today I went out in the boat and half way accross the harbour I found I couldnt trim up. When I found somewhere to stop, I found the trim button doesnt work in either direction and now the trailer button doesnt work either. So I had to completely submerge the trailer to get the boat on without scraping the bottom, and had to leave the boat at the marina as it was no good to drive home with the leg all the way down. Will be having a word with them on monday.
    Mercruiser 4.3L assembly harleyman74 Mercury MerCruiser 0 05-25-2010 06:49 PM
    transom Tilt and Trim switch dwmax Original Mariah Talk 4 08-31-2009 08:10 PM
    Trim Tab not working. john elbro General Maintenance 4 07-28-2009 01:39 AM
    Non working trim switch River Man Original Mariah Talk 3 07-20-2009 05:19 PM
    Wanted: Transom mounted paddlewheel assembly WetWilly Mariah Parts For Sale & Wanted 4 03-13-2009 08:36 AM
    There are 332 users
