Questions on fresh water flush system
Old 05-01-2011, 09:35 PM   #1
csterner's Avatar
csterner is currently offline
My Model: Z275ST Shabah
My Engine: 6.2L Bravo III
Gallery Images: 9
Send csterner:
Default Questions on fresh water flush system
My boat has the petcock valve in front of the engine and this is where it draws water into the water pump. It is not through the lower outdrive like most. So it is a pain in the butt to crawl under the boat and trailer to put the pole mounted water flusher under there. I wanted to put a "T" at the petcock and run a line up to the topside of the boat next to the cleat and put a closeable water hose fitting. This way all I have to do is open the fitting and screw my garden hose in, and then crank the engine.
So here is the million dollar question: Has anyone done this? I want to make sure I do it correctly, but it seems like such a simple task. The only hard part would be cutting a hole in the outer deck.
2001 Shabah Z275 ST
6.2L Merc with Bravo III
    Fresh Water Cooling System Zackattack Original Mariah Talk 9 08-20-2011 06:03 AM
    where is fresh water intake on 6.2L? csterner Mercury MerCruiser 1 04-21-2011 12:40 AM
    Installing a fresh water cooling system 7.4 L Bravo ginodesico Mercury MerCruiser 0 06-15-2010 02:48 PM
    Switch for fresh water bottle tonys87monte General Maintenance 0 05-10-2010 10:27 PM
    Hot water flush Buffalo_Bill Original Mariah Talk 2 07-08-2009 08:02 AM
    There are 410 users
