Alpha One and Gear lube
Old 07-15-2010, 02:23 AM   #1
jth21usa is currently offline
My Model: 233
My Engine: 5.7
Send jth21usa:
Default Alpha One and Gear lube
I had to change the gear lube on my 1994 Davant(5.o lx alpha one)i. The orginal gear lube is cream and not mercury. Can I mix the two?Ii've purchased mercury gear lube already and have no idea what the other brand is. I can clean out the reservoir but can't think of a good way to flush this out of the internal parts. Any info would be awesome thanks.
Justin Hafner
[email protected]
  • Old 07-16-2010, 11:26 PM   #2
    IowaWing is currently offline
    My Model: 190 Talari
    My Engine: 4.3 L Alpha 1 Gen2
    Send IowaWing:
    Default Re: Alpha One and Gear lube
    Gear lube is "cream"? Do you mean milky?
    If so, you have water in the outdrive lube and need to get that out of there right away. I would clean the reservoir and refill with correct lube too. Make sure you have drained the existing lube from the outdrive by leaving both of the plugs out for a couple of hours. Refill the outdrive with correct lube per instructions and check condition of lube after your next outing. If milky again, you need to get the outdrive resealed by a Mercruiser mechanic. Do not mess around with this issue as you could destroy the outdrive by running it with contaminated lube.
    IowaWing
    Steve
    Alpha 1 Gear Lube use problem sjrowan007 Mercury MerCruiser 8 05-09-2012 12:53 AM
    question on drive lube superman30 General Maintenance 2 06-16-2010 04:06 AM
    Drive lube oil Brian Boating 101 15 08-10-2009 12:19 AM
    need help changing gear lube on alpha one outdrive. pimpadelic General Maintenance 9 07-01-2009 05:41 PM
    Steering Lube jakejorgenson General Maintenance 1 01-27-2009 03:25 PM
    There are 377 users
