Torn exhaust bellows advice?
Old 05-26-2010, 10:49 AM   #1
brimerianzan's Avatar
brimerianzan is currently offline
My Model: 225 Davanti
My Engine: 5.7 Alpha
Send brimerianzan:
Question Torn exhaust bellows advice?
A respected marine mechanic says that I can operate my boat safely without my exhaust flapper and a torn exhaust bellows. See picture: exhaust flapper came loose and tore exhaust bellows. Replacing exhaust flapper very expensive and not needed unless I was to drive backwards 100mph. And its been suggested I can drive boat with torn exhaust bellows. Anyone else have this?
  • Old 05-26-2010, 01:29 PM   #2
    Default Re: Torn exhaust bellows advice?
    This is an argument that has been hashed out in numerous boating forums but I'm going to 'respectfully' disagree with your mechanic on part of his answer. Yes, you can operate the boat with a damaged exhaust bellows. A normal bellows usually has a drain hole in the bottom anyway so that area can get wet but i would replace the flapper as you risk a back surge of water (say when you come off plane quickly or wave conditions while tied up in a slip) entering the exhaust tube & getting into your engine then causing damage to your exhaust valves or a hydroloc. Think of the flapper as a little 'preventative insurance'.
    Old 05-26-2010, 08:25 PM   #3
    IowaWing is currently offline
    My Model: 190 Talari
    My Engine: 4.3 L Alpha 1 Gen2
    Send IowaWing:
    +1 Mikeyt
    I agree, it's lots cheaper to replace the flapper vs the engine.
    IowaWing
    Steve
    Bellows Replacement Paul Z General Maintenance 1 05-25-2010 03:04 AM
    Replacing Bellows Paul Z General Maintenance 3 03-23-2010 04:43 PM
    Mariah z240 w/New Mercruiser MPI 7.4L new Gimble/Bellows Denelli Mariah Boats For Sale & Wanted 1 10-11-2009 03:55 AM
    Exhaust TALLRAM Original Mariah Talk 2 12-17-2008 05:08 PM
    Bellows repair. Paul Z General Maintenance 2 03-11-2008 12:55 AM
    There are 315 users
