engine acting wierd at full throttle
Old 05-30-2008, 05:31 PM   #1
MariahMX20 is currently offline
My Model: 1991 MX20
Send MariahMX20:
Default engine acting wierd at full throttle
my drive is a omc cobra but no one looks at that section so i am going to post it here since it could be a similar issue to a merc drive. i have a ford 302 h.o. motor and when i am at full throttle sometimes it will just kinda die out and drop down from around 4000 rpm down to like 2500 and i loose all speed. everything i have checked seems fine and if i stop, turn her off and then start it again it will be fine. my two theorys right now are 1 the fuel pump is starting to fail or 2 the shift module is kicking on when it should not which would screw up the timing and i am really starting to think that is the issue at this point since i know the linkage is not adjusted perfectly yet . any other ideas? i want to mess around with it this weekend but we just got dumped on with rain and the river is a loggy mess. hopefully sunday maybe.
  • Old 07-03-2008, 01:52 AM   #2
    Captain Steve's Avatar
    Captain Steve is currently offline
    Send Captain Steve:
    I hope you have solved your problem already. From your description you might be getting vapor lock in your fuel delivery system. I have never had it, but seems to me that heat could cause fuel to vaporize and interrupt the considerable flow your 302 demands at WOT.
    Regards,
    Captain Steve
    Valparaiso, IN
    Old 07-03-2008, 02:51 AM   #3
    I think its cuz you have a Ford motor......
    Old 07-03-2008, 08:14 AM   #4
    Hi MariahMX20,
    Do you have electronic ignition on your motor? I have seen this on several cars before and it was due the ignition modules.
    Doubt it's the fuel pump, typically turning the motor off then right back on won't cure a pump issue. Have you changed you fuel filter lately?
    I would think if the shift module was kicking in, it wouldn't do anything to your motor. Shifter modules typically prevent motor start unless the shifter is in neutral, like a simple starter kill switch.
    Good luck and let us know what you find,
    Old 07-03-2008, 12:09 PM   #5
    My Model: 1991 MX20
    Send MariahMX20:
    the ignition is a prestolite ditributor that is fully electronic and has had everything replaced inside. fuel pump is mechanical so turning it off then back on would not cure it, the diaphram may need to be replaced. i have had the boat out twice with no shift module hooked up and have had no issues. on a omc cobra which is the drive i have, the shift module assists in shifting, it porpusly messes with the timing on the distributor so that the engine drops in rpm while shifting therefore the gears can lock in at a lower rotation speed making super smooth shifts. so far i am guessing ita a misadjusted shift switch, the actual switch that controls the module. thanks for the help!
    Old 07-03-2008, 12:18 PM   #6
    My Model: 1991 MX20
    Send MariahMX20:
    you know, i hated the ford engine when i got it, i am a chevy guy and build small blocks for my project cars all the time, i know a ton about chevys. i always use to talk about swapping the drive and engine over to a 350 chevy and bravo 1 but i have to tell you, i have fallen in love with this engine and drive combo, it is a great setup! only downfall is that parts in town are unheard of so i have to order everything online which is fine because i do all of my own work on my boat. of all of my boat problems not a single one has related to the motor itself. i also have added side exit corsa exhaust on this boat and you can ask anyone in my marina, they know my boat is coming whether coming up river or just pulling into the marina, kinda of like a mustang, it has a distinct sound and even a chevy guy will admit that a mustangs always have a nice sound to them. i guess i have to say is you shouldnt talk down on something like a ford motor until you have owned a boat with one.....
    Old 07-03-2008, 02:00 PM   #7
    i wuz kiddin'.
    Old 07-16-2008, 05:00 AM   #8
    dieselwiezil is currently offline
    My Model: 2000 Mariah 212 5.7V8 Mercruiser Alpha I 21p mirage plus 48-13702
    Send dieselwiezil:
    have you changed your fuel filter? There is one up on your carb too.
    2000 Mariah 212 Mercruiser 350
    2002 F150 Supercrew
    1996 F250 Diesel lots of power goodies.
    "Out of everything I have, I still prefer riding MARIAH"
    Old 07-16-2008, 12:10 PM   #9
    My Model: 1991 MX20
    Send MariahMX20:
    i have not been in my boat too much since we have went from flooding to drought here in omaha, that and we have been boat pooloing using my buddies baja so i have not confirmed yet but i am pretty sure the misadjusted shift module is the issue. i unhooked it and have taken it out twice since then with no issues, now if i can just get the time to go down and get it adjusted i will be set!
    Throttle Body Restriction?? Jeff Barnett Mercury MerCruiser 13 08-31-2011 02:20 PM
    Throttle Control Shifter Question? Douglas Alderman Original Mariah Talk 21 06-25-2009 07:44 PM
    New owner with some problems n(throttle,temp gauge,etc) jasfiveo Original Mariah Talk 2 05-20-2008 02:46 PM
    Throttle and shifter question.. Jeff Barnett Original Mariah Talk 3 09-19-2007 12:30 AM
    Battery box full of water dudders General Maintenance 5 08-28-2007 12:35 PM
    There are 302 users
