How do you tell how many hours an engine has?
Old 07-06-2008, 03:46 PM   #1
jchemotti is currently offline
My Model: 180SE Shabah
My Engine: 3.0 LX
Gallery Images: 1
Send jchemotti:
Question How do you tell how many hours an engine has?
I'm looking at another Mariah to buy, and have found one that I'm very interested in. The thing is, I'm a little doubtful about the hours on the engine that the owner claims -- is there an objective way to check engine time, other than experience?
Thanks.
Jan
1997 Shabah 180SE
3.0 LX - Alpha
A perfect mix ~ my dog, a book, my boat.
  • Old 07-07-2008, 01:38 PM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    I forget what year they started, but MerCruiser engines have a computer that a technician can hook up to and tell what the actual running hours are. I want to say late 80's or early 90's, but I could be way off. Try calling a MerCruiser tech. and see what they say. Maybe he could give you a full check of the engine/outdrive as well before you make a commitment to buy it.
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 07-08-2008, 01:45 AM   #3
    ChicagoWeb is currently offline
    Send ChicagoWeb:
    I have been trying to get the same information... My boat does not have an hour meter and the best guess is what we have been going off. My guess is there is about 375hrs on it now... But I have no way to confirm it.
    ___________________
    ChicagoWeb
    1996 - Talari z235
    23.5ft w/cuddy cabin
    Prestige Custom Trailer
    Lake Freeman, IN
    Lake Michigan, IL
    Old 07-08-2008, 01:26 PM   #4
    I'm not entirely sure, so you might want to check with your Mercruiser Technician, but I think you can only hook into fuel injected engines, because they're the only ones with an ECM and a data link.
    Old 07-08-2008, 02:27 PM   #5
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    ^ Yep. Carbed engines have no computer, so no record of the # of hours. Unless of course you have an hour meter connected. Even then, it's possible the gauge reading isn't true (mine runs when the key is in the on position, and the engine is not running...)
    A compression test might give you an idea of how "tired" the powerplant is, but it would be still be anyones guess as to the actual number of running hours on it.
    My Mariah
    Old 07-10-2008, 01:17 AM   #6
    GrayDog is currently offline
    My Model: 1995 Davanti 205
    Send GrayDog:
    A quick check that will give you an idea of it's general condition... pop the oil fill cap on the valve cover and have a peek. If there is no sludge and only slight staining of the head and rockers, the engine is probably in pretty good shape. If you can't see bare metal, walk away. The motor hasn't been maintained properly.
    How many hours on your Mariah?? supastipa Original Mariah Talk 137 12-10-2013 01:02 AM
    2001 Merc 6.2 High Hours greencanuck Original Mariah Talk 8 04-05-2008 12:05 PM
    There are 425 users
