96 Shabah 5.7 Merc, Bravo 3, wont go forward
Old 07-07-2017, 11:24 PM   #1
shanomcd is currently offline
My Model: 210 s Shabah
My Engine: 5.7 Bravo III
Send shanomcd:
Default 96 Shabah 5.7 Merc, Bravo 3, wont go forward
Hey All,
Long time.. I usually get all my stuff from the Facebook page! Love seeing Mariah's all around the world!
Anyhoo,
Tuesday, July 4th had a great day on the lake.. All Day!! Boat ran great, had a ton of fun. End of the day, pulled to the Marina dock, tied up, let some people off.. Got back in the boat, Wife untied, gave me a small push, etc... Drive wont engage forward! Messed with it for a second, still nothing. Tried reverse, worked great.. Backed right back to the dock.
Messed with it some more, still no forward, but reverse works fine. Pops right back to neutral from reverse too.. Just no forward.
Took the shift box apart this morning, all the linkage looks good and operational. The cables seem to be good and smooth. Shifting is not hard. Also watched the linkage back on the motor, all seems good from the shift box to the linkage plate. I cant tell beyond that. I know I am not supposed to shift while not running, so I have kept that to a minimum..
Any thoughts?? I have heard horrible rumors about some "castle gears" in the Bravo 3.. to the tune of about 2500.00?? YIKES!
I was hoping for a bit of Bravo 3 advise about similar things that I can check out!!
Thank you all a ton!
Shano
  • Old 07-08-2017, 03:07 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: 96 Shabah 5.7 Merc, Bravo 3, wont go forward
    Let's hope the shift cable end has come off or slipped out of the spring loaded coupler on the outdrive. You will need to pull the outdrive to know for sure.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 07-08-2017, 09:04 PM   #3
    1996 Mariah Z252 is currently offline
    My Model: Z255 Shabah
    Send 1996 Mariah Z252:
    Originally Posted by shanomcd View Post
    Hey All,
    Anyhoo,
    Shano
    I had a similar issue before. Exept mine worked but it was very difficult to engage in both directions. This may be your upper Stern drive unit like it was for me. Hopefully it's not!
    99 Merc 5.7 with Bravo 3 MEFI3 question GaryDoug Mercury MerCruiser 10 09-04-2017 10:31 PM
    Intro - 2000 Mariah 268 Merc 7.4L Bravo III radhat Introductions 3 11-15-2016 09:35 PM
    Merc Bravo III Problem 1621Mariah Mercury MerCruiser 5 08-27-2012 11:26 PM
    forward in reverse karae225 Mercury MerCruiser 4 06-15-2010 10:21 PM
    Control arm not shifting out of forward Lunaticutah Original Mariah Talk 3 06-26-2009 04:14 PM
    There are 238 users
