Gimbal bearing replacement
Old 09-02-2016, 10:26 PM   #1
robsx18 is currently offline
My Year: 2005
My Model: SX18
My Engine: 3.0L Alpha
Send robsx18:
Default Gimbal bearing replacement
Hi guys , how many have had trouble getting the old gimbal bearing out.
Alpha 1 Gen11
Mine is stuck in hard.
Tried slide hammering etc to no avail.
Awaiting the correct puller turning up, sux to have to buy it but once i hve it this won't be a pain next time.
Getting ready for summer in Aus .
Thank you robsx18 for this useful post!
pllevine (09-03-2016)
  • Old 09-03-2016, 03:48 PM   #2
    Bdbwtie is currently offline
    Send Bdbwtie:
    Default Re: Gimbal bearing replacement
    Alpha 1 Gen11
    Autozone rents a slide hammer, and an axle bearing puller kit. Comes with 3 different sizes. One you have to get just right to get it to slide into gimbral. with the right puller and slide hammer it shouldn't come to hard. Depending on how old, condition, might have to slide hammer it pretty hard
    Old 09-03-2016, 03:55 PM   #3
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    Do they have AutoZone stores in Australia?
    1998 202 Shabah 5.0L Alpha 1
    Phil Levine
    1998 202 Shabah
    Old 09-03-2016, 04:01 PM   #4
    Send Bdbwtie:
    oops didn't realize he was from Australia!
    On second thought, don't they have autozones everywhere? lol
    Old 09-03-2016, 04:03 PM   #5
    pllevine's Avatar
    Send pllevine:
    I was wondering that myself... Amazing though... How Mariah Boats are all over the planet.... I wonder if there's a membership list by country?
    Phil Levine
    1998 202 Shabah
    Old 09-03-2016, 08:26 PM   #6
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    I've used both methods, slide hammer and puller. They can be real stubborn sometimes if the have any rust on them. I like to chuck a wire brush into my cordless drill and remove as much corrosion from the gimbal housing as possible. Then I soak the interface between the bearing and gimbal with PB Blaster. Next give the bearing race a smack inward with a BFH and a bar just to break any corrosion between the race and the gimbal housing. Either puller method should now work although I prefer the threaded rod puller.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 09-03-2016, 10:55 PM   #7
    My Year: 2005
    My Model: SX18
    Send robsx18:
    Cheers for the feed back guys.
    Yeah its a stubborn one. Have done them before but haven't had one this tight
    Used a decent slide hammer, no good.
    Have to clean it up a bit and soak it then will use the puller when i get back home.
    No hurry at the moment, leg is serviced and ready to go back in.
    Haven't had the boat long so just going over it while the weather is cooler , getting ready for a maintenance free summer .
    Old 09-14-2016, 02:24 AM   #8
    My Year: 2005
    My Model: SX18
    Send robsx18:
    Update, bearing done and all back together happy.
    The bearing took some pulling even with the correct puller.
    Worth every cent that thing.
    Done alignment check while there (made up the tool at work)
    Only snag was having to split the lower leg again as the impeller (new) had two vanes going the wrong way.
    Water tested , all happy and quiet.
    Summer is coming
    Old 09-15-2016, 01:22 AM   #9
    kylakerat's Avatar
    kylakerat is currently offline
    My Model: Z220 Talari
    My Engine: 7.4 Bravo III
    Send kylakerat:
    Is it just me, or is it odd to see someone doing the spring maintenance and getting ready for summer....in September! Here in the northern hemisphere I'm currently debating squeezing in another trip or two, or just going on and winterizing.
    Glad the bearing finally pulled. Have a good summer!
    Old 09-15-2016, 01:49 AM   #10
    My Year: 2005
    My Model: SX18
    Send robsx18:
    Haha, i suppose it would be odd for you guys in the Northern Hemisphere .
    But down here in Perth Aus, we can boat nearly all year round.
    Went out Tues arvo, it was 18 deg C. A littile cool, had to wear a jacket but it as a beautiful sunny day on the Swan River.
    Wanted: Gimbal bearing, seal, and bellow kit Cory Mariah Parts For Sale & Wanted 2 03-23-2015 05:10 PM
    gimbal bearing doesnt wanna budge Txtruckerpaul Original Mariah Talk 9 03-22-2014 12:06 PM
    Gimbal bearing? janderson725 Original Mariah Talk 7 07-05-2012 02:32 PM
    Gimbal bearing or U-joint unlikeno1 Mercury MerCruiser 5 05-27-2010 08:00 PM
    Gimbal bearing wssb11 General Maintenance 16 01-01-2009 08:01 PM
    There are 300 users
