Gimbal bearing?
Old 06-30-2012, 12:46 AM   #1
janderson725 is currently offline
My Model: 222 Shabah
My Engine: 350 hp with Bravo III
Send janderson725:
Default Gimbal bearing?
Took my boat 2000 222 in to have the gimbal bearing replaced. Heard a clicking noise in the lower unit of my bravo 3. Mechanic found fine metal shavings in the lower unit after inspection. He can replace my bravo 3 with a bravo 1 for $2,500. Should I do this? Or Should I drain and refill the gear lube and just go on as usual? Either option can be completed by lunch tomorrow so I'll be able to get on the water. Any opinions would be helpful.
  • Old 06-30-2012, 01:23 AM   #2
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    Default Re: Gimbal bearing?
    I have heard that you can switch out the Bravo III for a Bravo I. I have also heard that a lot of really high performance boats use Bravo I's because they are lighter and smaller(less drag in the water). Not sure if any of that is true, but it would be interesting to hear from someone who has done it or knows more about it.
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Old 06-30-2012, 01:49 AM   #3
    Send janderson725:
    Yeah, I've heard the same things. I would really like to hear from somebody that's done it. My boat rides really smooth right now, I hate to mess up a good thing.
    Old 06-30-2012, 01:51 AM   #4
    Send janderson725:
    The bravo 1 in question is used and came off a baja.
    Old 06-30-2012, 02:07 AM   #5
    A B1 should bolt right on in place of the B3. I suspect you will lose a bit of your handling ability at slow speeds around the docks etc and possibly a bit of your holeshot & quicker to plane ability. I would think that as the B1 is lighter & smaller with less drag you might see a slight top speed increase and its probably far easier & less costly to find props for it. One issue to check on though is the gearing. I think (cuz i'm not certain) that you will need a 1.50 : 1 drive gearing for the B1.
    I gotta think there is some salvage value in that B3 though to offset the B1 cost?
    Old 06-30-2012, 02:01 PM   #6
    mikesnowman's Avatar
    mikesnowman is currently offline
    My Year: 97
    My Model: 272 Shabah
    My Engine: 7.4 mag
    Send mikesnowman:
    there is a huge difference in hole shot and midrange response. it all depends on what you are going to do. If you are using the boat for skiing and tubing stay with the 3
    Old 07-03-2012, 02:28 AM   #7
    Send janderson725:
    Turned out to be a non-issue. Gonna stick with the bravo 3. Thanks for the input!
    Old 07-05-2012, 02:32 PM   #8
    PlumLazy's Avatar
    PlumLazy is currently offline
    My Model: 210
    My Engine: 5.7, Bravo III
    Send PlumLazy:
    Glad you were able to keep the Bravo III. Unless you really trust the boat mechanic, I'd be wary that he might have been trying to dupe you out of your high-dollar drive. And yes it's a simple bolt-on to replace a Bravo 3 with a Bravo 1 or 2 lower unit.
    Bob
    Canyon Lake, TX
    '94 Shabah Z211, 5.7 Bravo III
    Gimbal bearing or U-joint unlikeno1 Mercury MerCruiser 5 05-27-2010 08:00 PM
    Bearing Size? dakotaman728 Trailering and Tow Vehicles 4 01-29-2010 02:09 AM
    Stuck Gimball bearing sirbb Mercury MerCruiser 4 04-22-2009 09:05 PM
    Gimbal bearing wssb11 General Maintenance 16 01-01-2009 08:01 PM
    There are 295 users
