Possible New Owner 94 Barchetta
Introductions
Old 06-30-2014, 09:49 PM   #21
Default Re: Possible New Owner 94 Barchetta
Originally Posted by Bosgarage57 View Post
Thanks Mikey, the impeller doesn't seem hard, but you have to take the drive out right? It seems like a big job to do.
The issue with the trim is it wasn't trimming up enough, if the gauge isn't calibrated how are others able to trim effectively?
I was able to find the manual for the engine and drive thanks to the forum.
You dont need to take off the entire outdrive to replace the impeller, just the lower section.
Read my response in the other thread about the diffeence between the trim switch and the trailer switch.
  • Old 05-29-2019, 02:52 PM   #22
    Jimychanga is currently offline
    My Model: Barchetta
    My Engine: 4.3 Merc
    Send Jimychanga:
    Hi, did anyone here end up putting smart tabs on a barchetta? I have a 95 barchetta and would like to add tabs but am not sure if there is room, unless I can put them right next to the outdrive. Any insights appreciated!
    Old 05-30-2019, 01:17 AM   #23
    Read the "Smart Tabs" thread and all will be answered.
    New Owner 182 Barchetta Questions cswahl General Maintenance 2 03-26-2014 12:21 AM
    New Barchetta Owner snopro1978 Prop Talk 3 08-28-2012 01:07 AM
    new barchetta 192 owner co-barchetta-192 Introductions 2 08-10-2012 04:19 AM
    Just became a Mariah Barchetta owner! LouisPiat Introductions 1 07-28-2012 04:22 AM
    Hello! 95 z 272 Barchetta owner here luv2boat Introductions 3 08-13-2008 09:21 PM
    There are 364 users
