Possible New Owner 94 Barchetta
Introductions
Old 06-27-2014, 07:15 PM   #11
Tyler10r is currently offline
Send Tyler10r:
Default Re: Possible New Owner 94 Barchetta
i would pay 5k for that all day. i wish my seats didnt need redone. and yours is blue. = envious.
  • Old 06-28-2014, 10:05 PM   #12
    Bosgarage57 is currently offline
    My Model: Barchetta
    My Engine: 4.3 Merc
    Send Bosgarage57:
    Well I brought it home today. Got it for a bit less, tear in a seat and general 20 yr old nicks and scrapes. Changing the oil today, gonna take it out tomorrow. I did get an original owners manual, if anyone is interested I'll try to upload it to someone. I'm pretty excited, pictures to come tomorrow.
    Thank you Bosgarage57 for this useful post!
    gahooligan (06-29-2014)
    Old 06-28-2014, 10:18 PM   #13
    Mariah1's Avatar
    Mariah1 is currently offline
    My Model: Shabah Z198
    My Engine: 4.3 Alpha1
    Gallery Images: 9
    Send Mariah1:
    Great news
    Old 06-29-2014, 11:43 PM   #14
    Congrats! Thanks for the offer of the manual but we dont need it. The manual, useless as it is, didn't change over the years the boats were made. :-)
    Old 06-29-2014, 11:58 PM   #15
    My Model: Barchetta
    My Engine: 4.3 Merc
    Send Bosgarage57:
    well we took it out today, was a blast for a bit, but now theres issues
    1) After ridding tubes and ect for about 2 hours we took a break. come back and as soon as we started it the temp gauge shot up to over half of the gauge, and a loud beep started. Thermostat??
    2) The trim gauge/trim itself isn't calibrated correctly. We cant trim it all the way up, the trim adjustment are the 2 squares on the side of the motor correct? 1 for trailer and 1 for actual trim?
    is there a 4.3 lx motor manual anywhere?
    3) on the back bottom below the motor is a drain plug......It seems to leak water. we will probably have to take off the 3 screws
    Old 06-30-2014, 02:02 AM   #16
    ckolek's Avatar
    ckolek is currently offline
    My Model: z182 shabah
    Send ckolek:
    Check the impeller in the water pump, it may be worn.
    Old 06-30-2014, 02:23 PM   #17
    My Model: Barchetta
    My Engine: 4.3 Merc
    Send Bosgarage57:
    After talking to a marine shop they think it sounds like a faulty temp gauge. Going to try to remove the gauge, clean it and go from there. We plan on checking the impeller this winter and getting things up to date.
    Anyone know what kind of temp gauge it is, It is a Faria, but I guess what Im asking is, is it a 2" with a rubber gasket around it or will a temp gauge from an auto part store work.
    Old 06-30-2014, 06:09 PM   #18
    My Model: Barchetta
    My Engine: 4.3 Merc
    Send Bosgarage57:
    Well after talking to another shop they think it is the water pump in the alpha drive. Im a little leary over that, that's a big project to do and fix. It would definitely be a "this winter" dear, just to replace gaskets and things.
    Anyone have a troubleshooting for the waterpump in the drive to see if its working?
    We are still going to try to replace the gauge and see if that fixes it, but definitely don't want to blow up the engine before we even get to play with it.
    Old 06-30-2014, 09:32 PM   #19
    1: I'm inclined to agree it's the impeller. Those gauges very rarely fail while the impeller should be changed every 3-4 years. If it starts to break up it causes a blockage in the cooling system which leads to overheating and the alarm sounds. And....it's an impeller, not a 'water pump'. It's an easy replace job. If your mechanic told u its a major job it's time to get a new mechanic.
    2: The trim sensor and trim limit switch you 're referring to have a habit of failing. There is a troubleshooting guide in the Maintenance section. To replace them requires removing the outdrive. Most learn to live without the trim gauge working.
    2 1/2: Those manuals are available to contributing members. Check the STICKY at the top of the Introductions section regarding the benefits of being a contributing member.
    3: Are you referring to the bilge plug?
    Bosgarage57 (06-30-2014)
    Old 06-30-2014, 09:44 PM   #20
    My Model: Barchetta
    My Engine: 4.3 Merc
    Send Bosgarage57:
    Thanks Mikey, the impeller doesn't seem hard, but you have to take the drive out right? It seems like a big job to do.
    The issue with the trim is it wasn't trimming up enough, if the gauge isn't calibrated how are others able to trim effectively?
    I was able to find the manual for the engine and drive thanks to the forum.
    New Owner 182 Barchetta Questions cswahl General Maintenance 2 03-26-2014 12:21 AM
    New Barchetta Owner snopro1978 Prop Talk 3 08-28-2012 01:07 AM
    new barchetta 192 owner co-barchetta-192 Introductions 2 08-10-2012 04:19 AM
    Just became a Mariah Barchetta owner! LouisPiat Introductions 1 07-28-2012 04:22 AM
    Hello! 95 z 272 Barchetta owner here luv2boat Introductions 3 08-13-2008 09:21 PM
    There are 235 users
