new barchetta 192 owner
Introductions
Old 05-06-2010, 05:50 PM   #1
co-barchetta-192 is currently offline
My Model: Barchetta 192
My Engine: 4.6
Send co-barchetta-192:
Default new barchetta 192 owner
I recently purchased my first boat, a 95 Barchetta 192. I am currently on lake powell (7 days on a house boat). The wind is getting nasty and I some how have internet access (verizon card). With the wind keeping me inside I figured it would be a good idea to run a couple of problems by the community.
Vinyl - The boat has white and blue vinyl. The blue vinyl seems to be the most UV damaged and the high traffic areas (sun deck) have some good cracks. I have the original blue vinyl bimini and an after market bimini. Anyone know if they used the same vinyl for the bimini that they did for the seats? If so I want to have a upholstery shop replace the seat vinyl using the bimini top vinyl to keep the same color.
Gas gauge - the gas gauge seems to jump all over. My guess is that the gauge is rusted. Any good sources for the gauge?
Trim gauge - The trim gauge is not always accurate. Sometimes the gauge shows 3/4 down when it is full down. Sometimes it will not raise higher than 1/2 from the throttle control but appears to be 3/4 high when visually inspected. Sometimes the gauge is accurate.
  • Old 05-07-2010, 01:49 AM   #2
    Default Re: new barchetta 192 owner
    Ahoy co-barchetta-192 and welcome to the club!
    Let's see, I think I can assist with your second and third question but I will leave the first one to our members with better knowledge on the vinyl..
    If your needle is acting like a '70 Monte Carlo's Gas gauge, it might just be overly sensitive and if you click here, this thread by member rjobe will tell you how to calm that jumpy needle
    It definitely sounds like dirt and/or corrosion in the trim sensor on your outdrive, You can open the sensors up and try cleaning the contacts and if you click here it will show you how to replace them if they're bad or to adjust them.
    Old 08-10-2012, 04:19 AM   #3
    duwilliams is currently offline
    Send duwilliams:
    I have a 95 barchetta also...was also at lake powell last week. Bullfrog area. small world huh"?
    1993 Barchetta - New Owner with Prop Question Weezer Prop Talk 0 07-01-2009 12:06 AM
    Hello! 95 z 272 Barchetta owner here luv2boat Introductions 3 08-13-2008 09:21 PM
    New Owner seek manuals for 182 Barchetta dfwguy Original Mariah Talk 1 08-05-2008 12:17 AM
    94 182 barchetta / b weber brett weber Original Mariah Talk 4 03-27-2008 02:31 AM
    94 182 barchetta brett weber Introductions 6 02-20-2008 05:38 PM
    There are 298 users
