New owner 92 2350Z Hard Steering
Introductions
Old 06-17-2013, 01:21 PM   #1
bdrath64 is currently offline
My Model: 2350Z
My Engine: 7.4L Bravo One
Send bdrath64:
Default New owner 92 2350Z Hard Steering
I purchased a 1992 Mariah 2350Z at the end of last season here in the upper midwest. I noticed it seemed to be hard to steer but it being my first I/O I didn't think much of it. Now I have had another I/O owner and him drive it a bit and he said it was way too hard to steer. The power steering pump is full of fluid and belt is tight. Does anyone have any experience with this or where to start. It has 7.4L and Bravo one out drive. Thanks
  • Old 06-17-2013, 01:44 PM   #2
    Default Re: New owner 92 2350Z Hard Steering
    A site search reveals there are a large number of threads here discussing this issue. Have a read thru this one for likely answers to your problem.
    Four things are normally associated with this condition:
    1) Binding in the steering wheel assembly. (Parts are worn and/or need lubing)
    2) The steering cable. (inner cable is worn/cable lube is dried up/contaminated or both)
    3) The power steering system. (valve or internal pump parts mat be leaking causing drop in pressure)
    4) Gimbal pivots. (worn/corroded/out of lube)
    For starters, I would begin troubleshooting by isolating the cable/steering box/powersteering from the gimbal as I beleive this is the easiest to do:
    1) Start by removing the big pivot bolt holding the cable/powersteering valve to the gimbal steering arm.
    2) Now try turning the steering wheel, if it's still tight, your problem is either in the steering box or the cable (I would suspect the cable first), but if it's smooth then it's in the outdrive or powersteering system.
    bdrath64 (06-20-2013)
    Old 06-20-2013, 08:29 PM   #3
    My Model: 2350Z
    Send bdrath64:
    I appreciate your suggestions I will take a look at it tomorrow.
    Bill
    « Hello! | confused »
    Steering very Hard to turn asand1013 Original Mariah Talk 6 04-09-2013 11:39 PM
    hard steering michaelb Mercury MerCruiser 2 05-20-2012 12:08 PM
    Hard Steering Kirkyer Introductions 0 07-19-2009 12:53 PM
    hard steering duketter Original Mariah Talk 2 06-07-2009 02:47 PM
    Hard steering Jimh23 Original Mariah Talk 4 06-05-2009 10:52 AM
    There are 307 users
