Steering cable installation issues
Old 07-07-2010, 01:02 AM   #11
IowaWing is currently offline
My Model: 190 Talari
My Engine: 4.3 L Alpha 1 Gen2
Send IowaWing:
Default Re: Steering cable installation issues
The removable panels are the long uppermost ones. They are flush with the top surface the window channel mounts to on my Mariah.
IowaWing
Steve
  • Old 07-07-2010, 01:05 AM   #12
    depman160's Avatar
    depman160 is currently offline
    My Model: 2000Z
    My Engine: 5.0L Merc Alpha 1
    Send depman160:
    what about the lower panel...if you look at my pic, at the bottom of the molded plastic, there is another thinner piece that runs the length of the side down along where the cupholders and ashtray are....
    Any idea if they will come off the same way as the top piece?
    If only it could be summer all year long!
    Old 07-07-2010, 01:12 AM   #13
    Send IowaWing:
    Sorry, I do not know if they come off easily. I am sure they come off but it may be that they are attached to the back of the panel and it will have to be removed first. Maybe someone else has found out the answer and will chime in with that information.
    IowaWing
    Steve
    Old 07-07-2010, 01:15 AM   #14
    depman160's Avatar
    My Model: 2000Z
    Send depman160:
    I was going to try it...but given that it was 95 degrees with about 90 percent humidity and no breeze....I gave up long before I got to that point!
    Now that I have some better idea of what I am doing with the steering cable, hopefully I will tackle it again this weekend and if I can do it....hopefully take some pics.
    Thanks for all the help!
    2000 Z260 Steering Cable sean77atx Original Mariah Talk 6 09-06-2022 08:56 PM
    Z252 Steering Cable edward cossey Original Mariah Talk 0 04-19-2010 06:15 PM
    1998 shabah Z252 steering cable replacement edward cossey Original Mariah Talk 6 01-17-2010 07:48 PM
    Steering Cable Length 1999 182 Shabah 1999Mariah Original Mariah Talk 0 07-16-2009 03:12 AM
    Cable running to leg Colin Logie Original Mariah Talk 2 05-06-2009 10:41 AM
    There are 318 users
