Pierre, Shabah 252 2000 blower issue
Introductions
Old 08-23-2021, 12:22 PM   #1
Leahpierre is currently offline
My Model: Shaba 252
My Engine: 5.7 bravo
Send Leahpierre:
Default Pierre, Shabah 252 2000 blower issue
New to the cub.
Blower not working, alarm on, is it for that, easy to replace?
Thanks.
  • Old 08-23-2021, 09:56 PM   #2
    Default Re: Pierre, Shabah 252 2000 blower issue
    The alarm staying on is due to any/all of the following;
    a) - Oil pressure being too low
    b) - outdrive oil reservoir being low
    c) - engine is overheating
    The blower not working is either;
    a) - poor electrical connections
    b) - poor ground
    c) - blown fuse
    d) - blower failure.
    Old 08-23-2021, 10:06 PM   #3
    My Model: Shaba 252
    Send Leahpierre:
    Thanks Mike.
    Is there an alarm for the non functioning blower. While the motor cover is up and the engine RPM higher than 3k the alarm turns of. Thanks.
    Old 08-24-2021, 02:11 AM   #4
    There isn't an alarm for the blower afaik. What you're stating suggests you may have a cooling / overheating issue. Perhaps one of the large boat guys here can chime in.
    Old 08-24-2021, 11:45 AM   #5
    My Model: Shaba 252
    Send Leahpierre:
    The temperature gage is showing normal temp at any RPM.
    Old 08-24-2021, 02:04 PM   #6
    Ok, I'll assume you have checked your oil level in both the engine & outdrive reservoir? If they are both good, then my next thing to check / replace would be the oil pressure sensor unit. If i remember right the Quicksilver ones are about $125 new and aftermarket ones about $50 - $75. They are easy to replace and there are You Tube videos on that procedure with the 5.7
    1996 Shabah 180 Blower Vent Disconnected! shabah3768 Original Mariah Talk 4 09-19-2021 06:24 PM
    Bilge Blower - 1996 Shabah robborobborobbo General Maintenance 3 05-16-2017 06:28 PM
    '96 Shabah 210 - Electrical Problems: Bilge and Blower tstraszewski Introductions 2 06-16-2016 04:29 PM
    What Blower - 00' Shabah Z222 Dsg03svt Original Mariah Talk 2 05-09-2012 04:03 PM
    shabah question - blower ATI WS6 Original Mariah Talk 10 08-24-2009 03:34 AM
    There are 322 users
