1996 Shabah 180 Blower Vent Disconnected!
Old 08-06-2021, 03:26 PM   #1
shabah3768 is currently offline
My Model: Shabah
My Engine: 4.3L Alpha I
Send shabah3768:
Default 1996 Shabah 180 Blower Vent Disconnected!
I just bought a Mariah Shabah 180 and took it out on the lake once. I noticed my blower motor was working, but was very loud so I ordered a nice replacement. Yesterday when I went to replace it, I noticed that the ducting was just hanging and not venting anywhere! That really concerned me and I could smell the fumes buildup under the cover. I couldn't quite see where it should have been connected so I can fix it. Does anyone have a good idea where it is supposed to be hooked up, or pictures of the proper vent location(s)?
  • Old 08-07-2021, 12:23 AM   #2
    pole trick is currently offline
    My Model: 180 Shabah
    My Engine: 4.3 Merc
    Send pole trick:
    Default Re: 1996 Shabah 180 Blower Vent Disconnected!
    I have same boat it cover up at momant...if I remember right there 2 large hoses. one goes down it to lower bilge other goes to upper bilge area.
    They go up to blower motor then blown out upper vents just behind deck pad
    Old 08-07-2021, 12:26 AM   #3
    My Engine: 4.3 Merc
    Send pole trick:
    My blower is loud but it has to move slot of air...load might be normal...I can hear it over engine at slow no wake speeds. Check for fuel leaks if you got strong fuel smell just to be safe
    Old 08-07-2021, 12:53 AM   #4
    My Model: Shabah
    Send shabah3768:
    I got the new blower in there and thanks to the guys here and on facebook got the duct routed. I used a Chillout brand 3" blower and yes you can hear it but man what a difference in quality and output! It's not screaming and raising hell like the Atwood blower I just pulled out.
    Old 09-19-2021, 06:24 PM   #5
    Brick1091 is currently offline
    My Model: 200 Talari
    My Engine: 5.7 Alpha 1
    Send Brick1091:
    Mine is also detached I need to crawl back there and reattach but might as well put new hose in since I'll be back there
    blower , shabah 180 , venting
    Bilge Blower - 1996 Shabah robborobborobbo General Maintenance 3 05-16-2017 06:28 PM
    '96 Shabah 210 - Electrical Problems: Bilge and Blower tstraszewski Introductions 2 06-16-2016 04:29 PM
    bilge blower/vent hose routing for z302 herm5000 Original Mariah Talk 1 08-11-2015 03:19 PM
    What Blower - 00' Shabah Z222 Dsg03svt Original Mariah Talk 2 05-09-2012 04:03 PM
    shabah question - blower ATI WS6 Original Mariah Talk 10 08-24-2009 03:34 AM
    There are 313 users
