Wipe down sprays?
General Maintenance
Old 07-11-2013, 05:59 PM   #1
theeasynine's Avatar
My Model: z240 Talari
Send theeasynine:
Default Wipe down sprays?
What does everyone use for wipe down solutions after a day on the water? I usually just get right on the highway and air dry but sometimes the water level grime is hard to get off. I have heard water and vinegar but I'm not crazy about putting that on the gel coat. Thanks.
Patrick
  • Old 07-11-2013, 06:04 PM   #2
    Default Re: Wipe down sprays?
    I usually just air dry until i get home & then if the grime is bad i use Starbrite "Sea Safe" Hull Cleaner. Wipe on, rinse off.
    Old 07-12-2013, 02:35 AM   #3
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    I have mine stored down the road from my cottage and I think they use some kind of acid bath. However, they do rinse it down on an already crappy trailer before lowering it back onto mine.
    If I had a decent spot to store it, I would probably be going the same route as MikeyT does.
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Old 07-12-2013, 05:49 AM   #4
    Muriatic acid removes water spots and hull discoloration. $4 a gallon at walmart. Don't get it on your concrete though.
    Old 07-12-2013, 02:07 PM   #5
    What ratio mix do you use? 3 parts water to 1 acid?
    Old 07-12-2013, 02:25 PM   #6
    I used to use the Bass Pro Shop Heavy Duty Hull Cleaner. Worked wonders, and much cheaper than big name stuff ($11.99/32oz bottle!). They claim it doesn't use any harsh acids and it's environmentally safe. If you've got a Bass Pro around, go get some and try it out, you might be really impressed.
    Also, it should be mentioned that if you have a galvanized trailer, make sure and cover it up with a tarp if you use any of these cleaning products. It'll remove the protective coating and allow the bare steel to rust. AND don't forget to use gloves with whatever you use. Muriatic acid is also known as Hydrochloric Acid.
    Old 07-12-2013, 02:34 PM   #7
    The acid I have says use full strength on fiberglass. Its odor free so I imagine it is diluted.
    I don't use it for a "wipe down" but when the water line gets too noticeable I'll clean it with this.
    Old 08-08-2013, 03:28 AM   #8
    jetinspector's Avatar
    jetinspector is currently offline
    My Year: 1990
    My Model: 2000Z
    My Engine: Mercrusier 350
    Send jetinspector:
    I try to wipe it down after I pull it out of the lake. If you can wipe it dry and remove all the lake scuzz it will stay cleaner longer without having to use the harsh cleaners or the vinegar. My dad always used brown vinegar and water mix, it works really well. If you have a good coat of wax on the boat it wipes down really easily. It also gives the people I bring along something to do when they ask "how can I help" when I am securing the boat for the road!
    Old 08-14-2013, 04:18 PM   #9
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    I always hand dry mine when it comes out of the water. I just mix some boat wash with water in a spray bottle, it helps get the spots off that have dried before I get to them and leaves a nice clean look.
    This season, every couple weekends out I've been wiping down with Leverage and it is helping the spider crap and spots come off easier and easier. I'm not quite getting the deep shine I'd really like to have from it though. I think I'm going to try PBC Speed Gloss when my Leverage runs out because I've read a lot of good reviews on it lately.
    Old 08-31-2013, 04:42 PM   #10
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    +1 for the muratic acid. My walmart didn't have it, but our Tractor Supply did. I mixed it 50/50 with water. Used about a half a washcloth sized piece of terry cloth and wiped it down, then rinsed really well with water. Amazing! I have a new boat now.
    There are 366 users
