Battery chargers
General Maintenance
Old 03-04-2013, 12:48 AM   #11
csterner's Avatar
csterner is currently offline
My Model: Z275ST Shabah
My Engine: 6.2L Bravo III
Gallery Images: 9
Send csterner:
Yes, you can run your electronics while these chargers are running. On my boat, I plug in the shore power into a regular exterior outlet on my house and then I turn the switch on in the cabin for shore power and then turn the switch on for the battery charger. My battery charger is a trickle charger. That means the system will charge the batteries but then it once they are charged, the system will monitor your batteries and apply very small (or "trickle") amounts of voltage to the batteries to keep them fully charged. You can run all your electronics while this is going on. If you are at anchor, you can run a generator on your swim platform and run your shore power cable to your genny and run your charger that way as well.
2001 Shabah Z275 ST
6.2L Merc with Bravo III
  • Old 03-05-2013, 03:03 PM   #12
    Default Re: Battery chargers
    Good to know! Ill prob be getting a 2 bank charger then. Thanks for the info!
    New Battery andyc General Maintenance 1 05-03-2011 02:19 PM
    Wanted: Battery brian9120 Mariah Parts For Sale & Wanted 0 05-21-2010 02:13 AM
    Add a Second Battery bnussbaum Original Mariah Talk 4 12-31-2009 07:29 PM
    Dual battery Jbetschart Original Mariah Talk 5 11-04-2009 04:37 PM
    There are 341 users
