Alpha 1 Gen 2 Question
General Maintenance
Old 09-23-2012, 02:44 PM   #1
jarwiebe's Avatar
jarwiebe is currently offline
My Model: Z210 Shabah
My Engine: 5.7 LX Alpha I
Gallery Images: 2
Send jarwiebe:
Default Alpha 1 Gen 2 Question
Hi,
When I had my 5.7 running on muffs the other day I noticed that some exhaust and water was being discharged out of the front of the upper section of the outdrive, from the shift linkage area, (see photo attached). Is this normal? This may always be happening but I had never peeked in behind while the engine was running.
Cheers
Jake
1996 Z210 Shabah
Mercruiser 5.7LX
Alpha One Drive
80 Lb. SX Smart Tabs
  • Old 09-23-2012, 03:20 PM   #2
    Default Re: Alpha 1 Gen 2 Question
    I could be wrong but , I think it's probably just the exhaust boot leaking. No big deal , just time to replace. And do the u joint boot and shift cable boot too , cause if if it leaks , bad things happen fast.
    Check gimble bearing and drive alignment while your at it.
    Larry
    Old 09-23-2012, 04:20 PM   #3
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    Mine does the exact same thing. I was told this is normal and once the drive is lowered and the engine starts turning some rpm the exhaust and water moves fast enough to bypass the smaller holes and just comes out the prop. I haven't gotten down there to investigate closely yet though.
    Old 09-23-2012, 05:42 PM   #4
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    Thanks for the responses guys.
    I checked the Mercruiser Technician's Handbook and to me it looks like this would be normal, but I wanted my interpretation of the drawings to be confirmed or corrected if I wasn't reading them right. Really don't want to pull the drive if I don't need to (all checked out ok this summer when I did a long block re-power due to blown head gasket).
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Old 09-23-2012, 06:07 PM   #5
    Sounds like your good to go then!!
    I haven't really looked at mine when on muffs to be honest with you.
    I know my old cobra drive had slits in the bottom of the exhaust boot as husker stated.
    Larry
    Alpha One prop question Phlorida Prop Talk 21 09-04-2010 04:37 AM
    Alpha One SS RVSwisher Mercury MerCruiser 0 07-25-2009 09:38 PM
    Alpha One Gearing RVSwisher Original Mariah Talk 3 07-25-2009 03:34 PM
    '99 21z with 5.7l what ratio Alpha leg? anthonybradley Original Mariah Talk 4 10-02-2008 05:40 PM
    Alpha leg dudders Mercury MerCruiser 4 08-27-2007 03:02 PM
    There are 374 users
