Alpha One Gearing
Old 07-24-2009, 06:44 PM   #1
RVSwisher is currently offline
My Model: 1990 2000XL 5.7L Alpha I
Gallery Images: 3
Send RVSwisher:
Default Alpha One Gearing
How do I find out what the gearing for my 1990 XL 2000 is? I have a 5.7L (260HP) Mercruiser with the Alfa One drive. I can not find a tag or sticker any where that gives me the gear ratio.
RVS
  • Old 07-24-2009, 10:34 PM   #2
    Gallery Images: 3
    Send RVSwisher:
    Default Re: Alpha One Gearing
    Ok,
    I re-read an answer I had to the same quesiton awhile ago. On the port side of my outdrive, on the top of the Mercruiser label is stamped 1 50 R. Am I reading this correctly for a gearing of 1:1.5 and a right hand prop?
    RVS
    Old 07-25-2009, 01:17 PM   #3
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Is your unit a Gen II drive? If so then I believe you are reading it correctly. I have the same stamp and the same engine/drive combination. Do you know if the drive is original?
    My Mariah
    Old 07-25-2009, 03:34 PM   #4
    Gallery Images: 3
    Send RVSwisher:
    I had to purchase a new water impeller kit for my sterndrive, and to find out I have a Mercuiser Alpha One SS. I'm not sure what the diffrence is between an SS, Gen 1, and Gen 2 Alpha unit. Origially they gave me a kit for a Gen 1, and the bottom housing of the water pump was completely diffrent and would not fit.
    Anyone know what a SS is? The gearing for the SS's was either 1:1.5 or 1:1.3 something.
    RVS
    Gearing for 1990 2000XL RVSwisher Original Mariah Talk 1 06-29-2009 08:21 AM
    Alpha drive cracked shoc Mercury MerCruiser 8 04-30-2009 08:31 PM
    '99 21z with 5.7l what ratio Alpha leg? anthonybradley Original Mariah Talk 4 10-02-2008 05:40 PM
    5.7 Litre and 4.3LX Alpha One, is that original? ale5jandro Original Mariah Talk 14 07-16-2008 09:01 PM
    Alpha leg dudders Mercury MerCruiser 4 08-27-2007 03:02 PM
    There are 438 users
