Not Working
General Maintenance
Old 07-14-2011, 12:57 PM   #1
cardz826 is currently offline
My Model: 216 PC Talari
My Engine: 4.3L Mercruiser
Send cardz826:
Default Not Working
Just picked up my 97 211 SE Talari last weekend and I am just about done with the detailing. Once that is complete I will be posting pictures. My next problem is I noticed that the blower and the horn are not working. Every other swith (docking lights, courtesy lights, bilge, etc...) works except for those two. Is there a fuse box on the boat that a fuse could have possibly blown or is there something else I should check. PLEASE HELP!!!!! My wife and I would like to take the boat out this weekend but with no blower or horn Im not so sure its a good idea. More so the blower. Any help that can be provided would be much appreciated.
  • Old 07-14-2011, 04:35 PM   #2
    Snoopinrob's Avatar
    Snoopinrob is currently offline
    My Model: Z200 Shabah
    My Engine: 5.7L Alpha 1
    Send Snoopinrob:
    Default Re: Not Working
    Try looking for the fuse breaker panel up under the driver's console, on my 1996 Shabah Z200 it's on the side panel down low on the right. If it popped a fuse/circuit a white tab will be sticking out and just push it or them back in to reset the breaker, I'd look there first if you haven't already. If everything is good there I'd start checking the wiring connections at the blower switch and the horn. I'm no expert but hope this helps some! Good luck!
    Old 07-14-2011, 05:33 PM   #3
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    Yes like Snoop sad I woud check that panel first then the switch while your under there. Then the wires at the blower as I am not to familiar with Mariahs yet but I had the one come off the blower it self on my other boat, and on the other boat my horn packed it in.
    darkcalling
    Z 278 Limited
    Old 07-14-2011, 11:36 PM   #4
    Send cardz826:
    Thanks for the help. I found the fuse box and sure enough 2 blown fuses. They r replaced and both work great. Thanks again?
    Old 07-15-2011, 03:11 PM   #5
    Snoopinrob's Avatar
    Send Snoopinrob:
    That's great, I hoped it was something simple! Glad you're up and going for this weekend! Enjoy your new boat!
    Old 07-16-2011, 12:53 PM   #6
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Were they actually blown, or were the contacts just oxidized? We had two or three things that didn't work on Shazaam! when we first got her. (The interior lights and bilge pump for sure. Maybe one other thing.) All I had to do was pull all the fuses (during which I took the opportunity to catalog them), clean them and the fuse holders, put them all back and everything worked.
    Jim
    “The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
    Click Here --> Help Support The Mariah Owner's Club <-- Click Here!
    Old 07-18-2011, 11:51 AM   #7
    Send cardz826:
    Sorry for the delayed response SEMIJim. The fuses were actually blown, the contacts were broken. Just popped them out, popped 2 new ones back in (horn and blower) and I was back in business. Had a GREAT weekend and I absolutely love the boat.
    up trim not working michaelb Mercury MerCruiser 2 06-13-2011 12:42 AM
    New and working out problems jomark78 Introductions 2 09-05-2010 01:13 AM
    Blower Not Working!!?? toddneedham Original Mariah Talk 12 07-31-2009 02:34 PM
    Trim Tab not working. john elbro General Maintenance 4 07-28-2009 01:39 AM
    rev counter not working craig Original Mariah Talk 3 05-13-2008 12:31 PM
    There are 375 users
