Bench Seat Hinge Repair 180 Shabbah
General Maintenance
Old 10-31-2010, 01:02 PM   #1
RichB is currently offline
Send RichB:
Default Bench Seat Hinge Repair 180 Shabbah
Hi Chaps
After a bit of a bouncy ride out on the solent, it transpires that the screws securing the rear bench to the floor are just rather thin (but scarily long) self tappers that have ripped loose. Hinges are fine - just need to be resecured to the cockpit floor.
Obviously there are a few options on how to proceed - use some thicker self tapping screws being the obvious... but is there a recommended 'proper' solution?
Is there a way of getting under there easily enough to put in some decent brass bolts or something? Is there anything fragile under that area - does the fuel tank go that far back!?
Would one of those tapped screw in inserts (something like dynafix insertsdirect.com - Product Information - Screw-In Dynafix Inserts) work well in this situation?
Any advice on this would be great... for now the boat is on the river, but I hope to go bouncing on the big water next year again! See what else falls off
Cheers all.
  • Old 10-31-2010, 02:11 PM   #2
    Default Re: Bench Seat Hinge Repair 180 Shabbah
    It must have been a bouncy ride.
    The petrol tank goes back as far as the sender unit which you should find just under the carpet in front of the motor but its a fairly narrow tank. I would consider using the Dynafixx inserts possibly making sure they stay anchored with some 3M 5200 when installing them. There is no way that i know of (other than ripping the floor decking out) to install bolts/nuts. If you have a look in the brochure (they're online here) you can see how the flooring etc is constructed.
    Old 10-31-2010, 08:58 PM   #3
    Send RichB:
    Thanks, I'll check out the docs.
    bench seat , repair
    looking for a place to buy hinge urim Original Mariah Talk 8 10-29-2014 04:38 PM
    bench hinges tfn1977 Original Mariah Talk 11 10-31-2011 09:05 PM
    Starter problem on 180 Shabbah RichB Original Mariah Talk 7 10-18-2010 10:13 PM
    Shabbah in London RichB Introductions 3 10-18-2010 08:35 PM
    Bench Seat Hinges Kuli Original Mariah Talk 1 05-01-2008 12:33 PM
    There are 226 users
