Starter problem on 180 Shabbah
Old 10-17-2010, 07:57 PM   #1
RichB is currently offline
Send RichB:
Default Starter problem on 180 Shabbah
Hi Chaps,
Thought I'd share with you this little problem I have been having...
Late 90's 180SE.
Trying to start up, I hear the starter motor whirr, but no engine turning over. Guessing the starter motor not engaged.
Anyhow, I think I found the problem after stripping off the starter motor...
Mariah Starter Motor by bennett_rg, on Flickr
Anyone have any idea what might have caused this? I think a chunk of the casing is still inside the engine somewhere, fetching that out is my next job! The whole side of the cast aluminium cover on the starter motor is all cracked, and if you look carefully you can see where something has gouged lumps out of the casing! Looks like a sharks been at it!
  • Old 10-18-2010, 03:56 PM   #2
    Paul F's Avatar
    Paul F is currently offline
    Gallery Images: 4
    Send Paul F:
    Default Re: Starter problem on 180 Shabbah
    REALLY Hope I'm wrong.
    Better pull the head and make sure that there's not water in the engine. A hydrolocked engine will tear up a starter in no time.
    Old 10-18-2010, 04:18 PM   #3
    Send RichB:
    Hydrolocked... that sounds bad
    Old 10-18-2010, 04:38 PM   #4
    Paul F's Avatar
    Gallery Images: 4
    Send Paul F:
    Like I said, I didnt want to alarm you, but I read on another site about a boat owner whose starter broke some teeth, mechanic replaced the starter, THEN found out there was water in the cylinders.
    It's caused when water gets past the flaps on the exhaust. Usually happens on a sudden shut down or sitting on the beach and taking a large wave to the transom.
    It can bad, but not always. Get someone to look at it right away as rust could become an issue.
    Keeping my fingers crossed!
    Old 10-18-2010, 04:40 PM   #5
    Dutch180SE's Avatar
    Dutch180SE is currently offline
    My Engine: 4.3LX Alpha I gen II
    Gallery Images: 2
    Send Dutch180SE:
    Hydrolock (a shorthand notation for either hydraulic lock or hydrostatic lock) is an abnormal condition of an internal combustion engine in which an incompressible liquid, commonly water, has been introduced into one or more cylinders, causing immobilization or damage. Hydrolock can occur because an internal combustion engine must compress a volume of gas in order to operate, while most common liquids that could enter an internal combustion engine do not compress. If liquid is introduced at a volume greater than the volume of the combustion chamber at its minimum (top of the piston's stroke), the piston cannot complete its travel. Either the engine must stop rotating or a mechanical failure will occur.
    If a cylinder fills with liquid while the engine is turned off , the engine will refuse to turn when a starting cycle is attempted. Since the starter mechanism's torque is normally much lower than the engine's operating torque, this will usually not produce damage as long as the operator does not continue with the attempt...
    maybe this is occured ??
    Mike
    1998 Shabah 180 Supersport 4.3 V6 Alpha I
    Save a tree, eat a beaver..
    Old 10-18-2010, 07:00 PM   #6
    Send RichB:
    Thanks chaps, will make sure that's checked!
    Fingers crossed...
    Rich
    Old 10-18-2010, 08:45 PM   #7
    domraga's Avatar
    domraga is currently offline
    My Model: 218
    My Engine: Volvo 5.7GL / SX-M
    Gallery Images: 32
    Send domraga:
    Hi Rich, fit a new starter (try repowermarine.co.uk) take out your plugs and try to crank, any water will be pushed out of the block by the pistons. If you can, check inside the cylinders with a boroscope / torch to see if there is ay corrosion. If there is, chances of water in the cylinder is high. If there is any of the casing of the last starter, it could be behind the bellhousing, so unfortunately to remove this is an engine out job unless you can remove the shroud on the forward side of the bellhousing to see inside. Also, if you are in any doubt about water getting into the cylinders, the number one cause will be riser gaskets or corroded risers themselves, particularly if the boat has been in salt water. If you manage to escape by finding no water in the cylinders, change the riser gaskets and inspect the risers, it will put your mind at rest. I've just spent 8 months building a new 5.7L engine after freeze damage to my 5.0L last winter. Thankfully its all ok now, but I learned much about thee engines and know of some good people around the Thames area who can help if you run into trouble. Ive PM'd my number, if you want to call me I'd be more than happy to guide you thru a few simple checks.
    Thank you domraga for this useful post!
    RichB (10-18-2010)
    Old 10-18-2010, 10:13 PM   #8
    Send RichB:
    Cheers Dom, may take you up on that
    Shabbah in London RichB Introductions 3 10-18-2010 08:35 PM
    1999 Shabbah first time owner with a few questions... zzzino1 Original Mariah Talk 2 08-09-2010 01:22 PM
    Starter huntnfish Mercury MerCruiser 6 07-25-2010 04:41 PM
    Starter question PROPNUT Mercury MerCruiser 11 07-09-2010 06:36 PM
    Bad starter? Dogloop Mercury MerCruiser 9 07-03-2009 09:20 PM
    There are 221 users
