Prop trim and gauge problem
General Maintenance
Old 04-20-2011, 01:05 PM   #11
Send 300sflyer:
Default Re: Prop trim and gauge problem
Originally Posted by Vilanova View Post
Thank you very much for your help.
The engineer decided to install a new switch (having lifted it out the water and failed to adjust it). He actually cut off the old switch and installed the new one using water proof joints in the wires otherwise it would have been a very expensive job to remove everything and fit the full wiring.
Find a new mechanic. He should have replaced both sending units when he did the bellows. They are very easy to replace when it is all taken apart. Installing both the gauge and trim sending units might have added 1/2 hour to the job including connecting the new wires in the engine compartment. Splicing the wires is unacceptable, especially for a Merc dealer... They should know better!
    trim gauge tobqluu Original Mariah Talk 8 07-05-2012 02:44 PM
    another depth gauge transducer problem Dutch180SE Original Mariah Talk 12 08-06-2010 12:22 PM
    mariah sx19 mercruiser alpha trim up trim gauge bad mrtransistor Mercury MerCruiser 1 08-05-2010 03:37 AM
    Gauge Problem spanky1250 General Maintenance 0 03-22-2010 12:56 PM
    trim gauge no problem Original Mariah Talk 2 08-19-2008 09:18 PM
    There are 206 users
