Passenger dash makes squeaky noise
General Maintenance
Old 05-29-2009, 02:59 PM   #1
Vacation Dave's Avatar
Vacation Dave is currently offline
My Model: 1995 Z220 Talari 7.4L Bravo I
My Engine: 7.4L Bravo I
Send Vacation Dave:
Default Passenger dash makes squeaky noise
Over the years I had some clips fall off under the dash structure. I didn't know where they they went under the dash. Obviously, they had something to do with supporting the dash structure. I saved the clips in a plastic bag.
I now have a squeaky noise coming from the where the entire passenger side dash structure wraps around and meets the gunwale.
My question is, "Is there a schematic for attaching this dash with these clips and the position of the nuts and bolts". Basically this would be from the original dash structure assembly/ installation drawings.
I have a 1995 Z220 Talari.
Thanks Dave
  • Old 05-30-2009, 05:17 AM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Default Re: Passenger dash makes squeaky noise
    Do you have pictures of these "clips"?
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 05-31-2009, 03:14 PM   #3
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Have a look at: Can anyone ID this part?
    My Mariah
    Old 06-01-2009, 02:29 PM   #4
    jimshabbah is currently offline
    Send jimshabbah:
    I recently redid the entire interior of my boat and removed the dashes and had them re-painted. Those 'clips' look like the spacers or 'washers' that were used to bolt the dash to the fiberglass from underneath. If you have found them loose on the floor, I would suspect that a bolt or two have worked themselves loose from the dash. That would certainly explain the squeaks.
    Hopefully the threads aren't stripped, and you can just replace the bolt. On my Z222 I think there were 6 or 7 bolts per dash. Some bolts required more 'clips' than others. I think I had anywhere from 3 to 6 clips per bolt.
    Good luck.
    Old 06-01-2009, 10:48 PM   #5
    I had to reinstall a couple of mine that had worked their way loose over time. Just be careful that you dont overtighten them or you can crack the dash mounting points.
    Old 06-04-2009, 11:20 PM   #6
    Send Vacation Dave:
    Thank you all! Good information as usual.
    Z202's picture of the clip is right on
    I looked nder the dash some time ago and saw exactly what the threads back last August, 2008 discussed.
    Unfortunately, getting to the bolt posts takes a bit of a contortionist. i figure I'll need to use a flexible drill shaft to tighten the nuts down.
    Thanks for the heads up on the nylon bolts and caution to be used while tightening.
    Dave
    Old 06-04-2009, 11:22 PM   #7
    Send Vacation Dave:
    Z202's picture of the clip is right on I also looked-up the thread back in August, 2008 discussions. Again, great info.
    I looked under the dash some time ago and have forgotten where I had some missing.
    Unfortunately, getting to the bolt posts takes a bit of a contortionist. I figure I'll need to use a flexible drill shaft to tighten the nuts down.
    Dave
    Last edited by Vacation Dave; 06-04-2009 at 11:25 PM. Reason: Correction on sentence structure
    SX19 won't start and high pitch warning(?) noise 06_19SX Sea Fox - Mariah Talk 13 08-26-2023 01:26 AM
    Dash ice box lid Mach Man Original Mariah Talk 8 01-07-2009 04:12 AM
    Squeaky dash counsel blockp Projects 9 10-17-2008 03:22 AM
    Coast Gaurd Passenger plate Jason_Smith008 Original Mariah Talk 3 08-28-2008 06:58 PM
    Sale that makes you go hmmmmm.... Diablo180 Mariah Boats For Sale & Wanted 7 08-25-2008 07:29 PM
    There are 276 users
