white build up on outdrive
General Maintenance
Old 03-28-2009, 01:03 AM   #1
PROPNUT is currently offline
My Model: 1994 Talari 180 4.3L LX 4BBL Alpha One
Gallery Images: 4
Send PROPNUT:
Default white build up on outdrive
Can anyone tell me what I can do to remove the white build-up residue on my stern drive? It looks like corrosion, I think maybe from the exhaust. What can I do to get rid of this? This is my first I/O so I have not encountered this before. Thanks!
Propnut
  • Old 03-28-2009, 03:38 AM   #2
    indykoch's Avatar
    indykoch is currently offline
    Send indykoch:
    Default Re: white build up on outdrive
    Without seeing an actual picture, my guess is they're hard water stains and "calcium" type build-up.
    I've used CLR, Lime Away, and even Muriatic Acid (dilluted and rinsed right away) all with fairly good luck. Use a stiff brush, but not enough to scratch the finish. Good luck!
    Ryan
    Previously - '99 Z212 Shabah
    350 Mag MPI
    Old 03-28-2009, 03:53 AM   #3
    Gallery Images: 4
    Send PROPNUT:
    I was not sure if it was just from hard water residue or something else, like from the exhaust. Like I said, its my first I/O. I never got build up like this on any of my other boats that had outboards.
    Propnut
    Old 03-30-2009, 03:30 PM   #4
    lomitabob's Avatar
    lomitabob is currently offline
    My Model: 2001 Z250 Shabah 7.4LMPI Bravo I
    Gallery Images: 12
    Send lomitabob:
    Mine had had the same problem and it was scale buildup. I added a drive shower and it solved the problem. It keeps the drive cooler so I expect it will keep the bearings and oil in better shape.
    Old 04-02-2009, 11:05 PM   #5
    Gallery Images: 4
    Send PROPNUT:
    OK, what the heck is a drive shower? I spent several hours detailing the sterndrive. I used CLR, a toothbrush, a nylon brush, rags and a lot of elbow grease. What you are describing sounds good, but I don't know what it is.
    Thanks! Propnut
    Old 04-03-2009, 11:53 AM   #6
    to my understanding a drive shower is a small metal pipe that runs off flowing water as you drive, it forces the water up over the top of the outdrive to keep it cool.
    Here's One
    where exactly is your white buildup? on the top of the outdrive, or on the bottom half?
    Old 04-03-2009, 02:48 PM   #7
    lomitabob's Avatar
    Gallery Images: 12
    Send lomitabob:
    The one I put on is an earlier version of this one and I have not had any buildup since.
    http://www.driveshowers.com/
    They have good info at this site.
    Old 04-03-2009, 02:49 PM   #8
    lomitabob's Avatar
    Gallery Images: 12
    Send lomitabob:
    Sorry ShabahZ250 I didn't see your link
    Old 04-03-2009, 04:15 PM   #9
    blockp's Avatar
    blockp is currently offline
    My Model: 99 Jubilee 214
    Gallery Images: 8
    Send blockp:
    That white build is the mineral deposits left behind from water evaporating off the upper portion of the drive. The drive shower helps keep the upper portion of the drive cooler and subsequently you don't get the deposits.
    Like Indy said, use clr or a limeaway type product to get it clean.
    Old 04-04-2009, 02:15 PM   #10
    Gallery Images: 4
    Send PROPNUT:
    Thanks for the info guys! I will check out getting a drive shower. The boat is still "new" to me so I am just getting things figured out. Have a good weekend!
    Its time to build a boat!!! Mark Anderson Boating 101 3 09-23-2008 02:34 PM
    White light on a Talari 180 Tilted Original Mariah Talk 12 09-20-2008 12:49 PM
    White Anti-Fouling Bottom Paint ShabahZ280 Original Mariah Talk 6 07-25-2008 10:00 AM
    Mariah Build Quality?? Jeff Barnett Original Mariah Talk 9 02-24-2008 10:42 PM
    Rafting (not white water) 180diablo Boating 101 6 08-14-2007 06:20 PM
    There are 278 users
