Water Temp
General Maintenance
Old 04-27-2009, 09:02 AM   #11
Default Re: Water Temp
Originally Posted by millertime View Post
Do you have any web sites you can refer me to. I am mechanically inclined bot not on the way the water and outdrive work. I have a mariah 2350Z with the 454. I thought I had a fuel problem and it shut down. After looking at the temp gauge it was just around 250 degrees. You said you did it in the water and very little tools but I hace no idea where to begin on the impeller your talking about. Thanks Terry
Hi Terry,
See my reply on your other post. If you need further assistance, just give us a shout!
  • Old 04-27-2009, 07:17 PM   #12
    markkearns's Avatar
    markkearns is currently offline
    My Model: 1994 241 Davanti
    Send markkearns:
    As you can see its a common problem and not to costly to fix. I have no mech skills so I had a mech that I use for my boat come out and fix it. Took a couple of hours and about $200. I had some other minor issues so you could probably get it done for a little less.
    air/water temp gizmo moondance100 Original Mariah Talk 13 06-15-2020 11:40 PM
    What water temp does your engine run at? Jeff Barnett Mercury MerCruiser 15 05-13-2018 01:46 AM
    water temp clockwood Original Mariah Talk 2 01-21-2009 04:05 PM
    Air/Water Temp Guage Not Working MAJIC Original Mariah Talk 0 06-02-2008 01:02 AM
    Air Temp Sensor rjobe Original Mariah Talk 5 09-17-2007 02:45 AM
    There are 298 users
