Speedometer sensor replacement
General Maintenance
Old 05-16-2022, 04:52 PM   #1
DougEllefson is currently offline
My Model: Z225 Davanti
My Engine: 5.8 Bravo 3
Send DougEllefson:
Default Speedometer sensor replacement
I have a 1996 Davanti Z225 and the speedometer went out last year. I also recall the depth guage was random and innacturate.
Looking at the paddle wheel and cable, I see that cable has been munched.
I see replacement kits online, but I am not sure which one I need or if there is only one.
Is the sensor with the paddle wheel responsible for speed, temperature and depth?
Is this as simple to replace as removing the old one, feed the new cable in and connect it?
Thanks so much.
Newbie here. First day.
  • Old 05-16-2022, 05:46 PM   #2
    Default Re: Speedometer sensor replacement
    I'm assuming you have a 'paddlewheel' style sensor? Lots of You Tube videos on replacing the speed/temp sensor.
    Old 05-16-2022, 06:00 PM   #3
    Send DougEllefson:
    I could not really find anything on YouTube regarding my specific sensor. I did however find the replacement kit on Amazon. I'm sure I can figure out how to install it by just tracing the wiring and swapping parts.
    If it happens to he helpful for someone else, here's the link.
    https://www.amazon.com/Mercury-Quick.../dp/B000XBD7Y2
    Trim sensor replacement Brian Belcher Original Mariah Talk 3 05-24-2016 05:38 PM
    Air Temp Sensor jayws6 General Maintenance 0 04-11-2014 12:47 AM
    speedometer wheel sensor Shabahz242 Original Mariah Talk 2 06-25-2012 12:58 PM
    Outdrive Trim Sensor & Trim Limit Switch Replacement WetWilly General Maintenance 0 05-26-2009 06:01 AM
    Air Temp Sensor rjobe Original Mariah Talk 5 09-17-2007 02:45 AM
    There are 318 users
