U Joint Clicking When Turning
General Maintenance
Old 07-06-2017, 03:58 PM   #1
My Model: Z202
Send Firestone:
Default U Joint Clicking When Turning
Well being new to boats I have not run across this issue. When I start up in the morning everything sounds find and I can do hard turns forward and reverse with no issues. After about an hour I can hear a clicking sound that appears to be coming from the u joint during hard turns. The noise goes away when I straiten out, thus I thought it must be the u joint. I am not sure when the last time the u joint was serviced and did not know if it could just need to be greased? I would think if it was going out it would do it all the time? I have had it out 3 trips with the exact same result. Thoughts, opinions, or help is very welcomed.
John
  • Old 07-06-2017, 07:55 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: U Joint Clicking When Turning
    It could be the u joints needing grease or to be replaced. When was the last time you greased the coupler/splines. Everyone forgets that there are zerk fittings on the back of the coupler. It could also be the gimbal bearing that needs grease or replacing. I would start by greasing what you can.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 07-06-2017, 08:11 PM   #3
    My Model: Z202
    Send Firestone:
    Thanks Steve. I ordered both kinds of grease (u joint and 2-4-C). I will pull it out of the slip when they come in and grease it up.
    John
    Old 07-18-2017, 10:23 PM   #4
    My Model: Z202
    Send Firestone:
    Well, before I could grease anything the wheel started vibrating when I would turn it left or right and making a rapid clicking sound. Not having anywhere to work on my boat's outdrive I took it to a mechanic. I just received work that the u-joint and bearing are find and everything look good on the unit. His next place to go is steering. Just wanted to see if anyone else has run across this issue.
    John
    drive unit u-joint rust? Txtruckerpaul Original Mariah Talk 20 03-16-2018 11:37 AM
    Grinding when turning?! mike699 Original Mariah Talk 7 09-07-2011 08:51 PM
    Gimbal bearing or U-joint unlikeno1 Mercury MerCruiser 5 05-27-2010 08:00 PM
    Starter Clicking won't start?? Lake Norman Thunder General Maintenance 1 07-29-2009 03:51 PM
    U joint? Z212NH Original Mariah Talk 4 07-17-2009 12:04 AM
    There are 301 users
