U joint?
Old 07-16-2009, 02:29 AM   #1
Z212NH is currently offline
Send Z212NH:
Default U joint?
Hoping to confirm a problem I am having with a '99 Z212 with 350MPI and Alpha 1 drive. When making turns, especially at lower speeds, I am getting some pretty serious vibrations and rumbling noise. The noise and vibration go away at higher speed or even at lower speed as long as I am not turning.
I was told this might be a u-joint. Just wondering if that sounds right, and if it is, what they typically cost to replace.
Formerly known as "Mariah wanna be"
  • Old 07-16-2009, 01:07 PM   #2
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Default Re: U joint?
    What you describe sounds more like a bad gimbal bearing.
    My Mariah
    Old 07-16-2009, 04:09 PM   #3
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    I with Z202, my guess is gimbal bearing. Mine cost me about $300 to replace, but unsure of US $ prices.
    Tony
    Perth, Western Australia
    Old 07-16-2009, 05:46 PM   #4
    95Z212's Avatar
    95Z212 is currently offline
    My Engine: 5.0LX Alpha 1
    Send 95Z212:
    I would say the gimbal bearing as well. If it was a u joint at higher speeds it should vibration like a mofo, and at lower speeds make a clunking noise.
    1995 Shabah Z212 V8
    2012 CRF 450R
    My location
    Old 07-17-2009, 12:04 AM   #5
    Send Z212NH:
    Many thanks, that was the other possibility.
    There are 301 users
