How do i remove the Negative battery cables from the starter on my Z255?
General Maintenance
Old 05-13-2017, 04:17 PM   #1
1996 Mariah Z252 is currently offline
My Model: Z255 Shabah
Send 1996 Mariah Z252:
Default How do i remove the Negative battery cables from the starter on my Z255?
What is the best way to remove the negative battery cables from my starter? Its in a tricky place. My negative cables are all corroded so i need to replace them. Mercruizer 7.4
Sent from my iPad using Tapatalk
  • Old 05-13-2017, 06:14 PM   #2
    MTH
    MTH's Avatar
    MTH is currently offline
    My Model: Shabah 202
    My Engine: 5.7L A1
    Send MTH:
    Default Re: How do i remove the Negative battery cables from the starter on my Z255?
    What motor setup? With my 5.7 I had to use a 1/4" ratchet, 8mm socket with a short extension...
    99 Shabah 202 5.7 A1
    Old 05-13-2017, 06:27 PM   #3
    7.4
    Sent from my SM-G935V using Tapatalk
    Old 05-13-2017, 08:11 PM   #4
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    That may fix your radio problem as well.
    Old 05-13-2017, 08:14 PM   #5
    Think so? Awsome!
    Old 05-13-2017, 09:12 PM   #6
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    The negative battery cables are connected to studs on the rear of the bell housing on my 7.4, not to the starter
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    How do I remove the old tachometer? RodneyWest Original Mariah Talk 8 08-27-2020 03:12 AM
    Winter project: Dual battery setup, amp rack, battery monitor jjt1276 Projects 8 06-08-2017 03:47 PM
    99 Jubilee control cables jbird Original Mariah Talk 0 07-20-2011 10:55 PM
    Remove and Rebuild 4.3 Mec sirbb Mercury MerCruiser 1 04-05-2009 12:58 PM
    There are 325 users
