Broken fuel line
General Maintenance
Old 05-03-2017, 02:59 AM   #1
Unknownmariah is currently offline
My Engine: 350 magnum
Send Unknownmariah:
Default Broken fuel line
So in removing the carburetor I snapped the fuel line. I do not want to bend my own and would prefer to just buy a replacement. However I'm having a hard time locating one that looks identical to mine. I have a 350 magnum 94 Talari. Does anyone know the part number or where to locate a fuel line for this specific model?
1994 Talari 350 Magnum
  • Old 05-07-2017, 02:36 PM   #2
    Send Unknownmariah:
    Default Re: Broken fuel line
    Anyone??
    Old 05-07-2017, 11:49 PM   #3
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Would something like this work?
    https://www.amazon.com/Sierra-18-811.../dp/B000N9K0L2
    It may be impossible to find an exact replacement.
    Old 05-08-2017, 12:06 AM   #4
    Send Unknownmariah:
    Id like to keep it stainless steel
    Old 05-08-2017, 03:08 AM   #5
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Buy a coil of SS line at a local parts store (NAPA would be best) and have them make one for you using yours as a template. Actually SS pipe is more vulnerable to vapor lock problems than insulated composite hoses. If you really want SS, then consider braided/insulated SS.
    Thank you GaryDoug for this useful post!
    1996 Mariah Z252 (05-13-2017)
    Old 05-08-2017, 03:10 AM   #6
    Send Unknownmariah:
    I thought it was recommended to stick with factory parts, in this case SS? Isn't SS safer then a rubber tube?
    Old 05-08-2017, 03:14 AM   #7
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    Well, how did yours "snap"? Nothing fool-proof about metal lines. I would consider how hot it gets inside your engine compartment. Mine is very cool all the time, but I'm not sure that is normal. Synthetic rubber might not hold up if it's very hot.
    Old 05-08-2017, 03:29 AM   #8
    Send Unknownmariah:
    It snapped because its 23 years old and was weaked due to corrosion. It happened while removing carburetor. I thought that if rubber was a good idea the factory would have used it. Regardless I think I may have found a match using the engine serial number.
    7.4L MPI Stray Vaccuum Line jayws6 Original Mariah Talk 7 06-07-2013 04:32 PM
    Drive line oil question Kitto Original Mariah Talk 7 07-05-2012 12:57 AM
    212Z fuel line pick up? gdsoper Original Mariah Talk 1 03-19-2012 04:13 AM
    Looking for my fuel line on a 94 shabah Jbetschart Original Mariah Talk 9 01-28-2010 07:43 PM
    Broken Fuel tank cap latch audiomngr Original Mariah Talk 0 09-15-2009 04:13 PM
    There are 269 users
