Drive line oil question
Old 07-04-2012, 04:07 AM   #1
Kitto's Avatar
Kitto is currently offline
My Model: 2002 Diablo 200 5.0L Merc. Alpha 1
Gallery Images: 7
Send Kitto:
Default Drive line oil question
Hey fellas,
I have a 5.0L with the drive line oil reservoir at the front of the motor with the oil low, not bad, but definitely below the level. I know the mechanic put in the Mercruiser synthetic blend oil in. My local parts house has a petroleum based marine oil that I can use however it is not the blend. I spoke with a boat mechanic today and he said it would be fine as well as another boat owner. What say you?? I would love to get out on the lake tomorrow but don't want to run the boat at current oil level (which I know needs to be fixed) nor do I want to mix the two if it is not good. Please give me some advise. Thanks
Kitto
2002 Diablo 200 5.0L Alpha 1
  • Old 07-04-2012, 01:11 PM   #2
    Default Re: Drive line oil question
    Mixing petroleum based oil with synthetic oil will only cut down the performance and life of the synthetic oil. When you buy a synthetic blend oil you get a mix of mineral & synthetic.
    Old 07-04-2012, 03:58 PM   #3
    Kitto's Avatar
    Gallery Images: 7
    Send Kitto:
    Thanks Mikey,
    I did find some Quicksilver Gear Lube at Walmart (online) but I can't tell if it is a synthetic blend or not. How would a person be able to tell, would it say right on the bottle? Thanks.
    Kitto
    Old 07-04-2012, 06:29 PM   #4
    Yes, it should be marked right on the bottle.
    Old 07-04-2012, 09:13 PM   #5
    voodoo's Avatar
    voodoo is currently offline
    My Model: Davanti
    My Engine: 5.7
    Send voodoo:
    Originally Posted by Kitto View Post
    Hey fellas,
    You have the remote resevoir on the engine, it has oil in it?
    I don't think you have anything to worry about untill that remote resevoir is emptied...except where the oil went.
    Old 07-05-2012, 12:36 AM   #6
    Kitto's Avatar
    Gallery Images: 7
    Send Kitto:
    Dang! Really?! She's been running a little "off" lately, a little more noise and vibration at higher RPMs I was hoping that was my problem. I do have the reservoir and it is about a quarter of an inch below the bottom line. I have no leaks on my garage floor nor in the bilge so not sure what is going on??
    Kitto
    Old 07-05-2012, 12:46 AM   #7
    voodoo's Avatar
    My Model: Davanti
    My Engine: 5.7
    Send voodoo:
    It should not lose oil.
    The vibration may be from the drive line.
    Maybe a bad prop, bearings and/or leaking seal.
    Old 07-05-2012, 12:57 AM   #8
    Kitto's Avatar
    Gallery Images: 7
    Send Kitto:
    Yeah I figured I had a problem, however, I was hoping it was just a slow leaking seal. I had the whole driveline looked at a year ago and all was well, just goes to show what can happen in a years time.
    Kitto
    212Z fuel line pick up? gdsoper Original Mariah Talk 1 03-19-2012 04:13 AM
    Best way to fix a hair line crack? near windshield nglauer Original Mariah Talk 8 07-15-2010 09:48 PM
    question on drive lube superman30 General Maintenance 2 06-16-2010 04:06 AM
    Looking for my fuel line on a 94 shabah Jbetschart Original Mariah Talk 9 01-28-2010 07:43 PM
    oil line connection on lower unit shoc Mercury MerCruiser 4 05-15-2009 04:08 AM
    There are 302 users
