Blistered hull
General Maintenance
Old 09-10-2016, 06:26 PM   #1
Unknownmariah is currently offline
My Engine: 350 magnum
Send Unknownmariah:
Default Blistered hull
So I have a 94 Mariah Talari and my hull is covered with tiny blisters. Any of you fellow owners experience this? I'm debating on not fixing it and leaving it as is. Stupid?
1994 Talari 350 Magnum
  • Old 09-10-2016, 07:25 PM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Blistered hull
    Have not heard of this issue. Did you search the forum? Pictures?
    John
    Old 09-10-2016, 07:37 PM   #3
    Send Unknownmariah:
    Well its very common among fiberglass boats that are kept in water all season. One solution is to repair it and bottom paint it....no pictures because boats in water right now
    Old 09-10-2016, 09:12 PM   #4
    Hunter12345's Avatar
    Status: Silver Contributor
    Gallery Images: 2
    Send Hunter12345:
    Ya this is normally caused by the original gel coat application ive heard. Anomalies may allow the gel coat to be pourus, water gets between the gel coat layer.
    Depending on the severity, it can be a bit of work to repair but not impossible. It should be taken care of as the water pockets in time can compromisethe hull.
    Repair it and bottom paint so far is the way to go!
    1998 shabah 180
    5.7l 350 mag
    Bravo III
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 10-15-2016, 02:22 PM   #5
    The Grand Lakey's Avatar
    The Grand Lakey is currently offline
    My Model: 180 Talari
    My Engine: 4.3lx Alpha 1
    Send The Grand Lakey:
    I've just recently found out that my boat has these blisters as well. And look as though they have appeared all over this year. My lake dropped so low my boat was pretty much parked in mud. Wonder if it had anything to do with it?
    Thru Hull exhaust doucas Original Mariah Talk 1 02-15-2012 05:25 PM
    I this the same hull CARL SWINDLE Sea Fox - Mariah Talk 1 06-04-2010 02:02 PM
    hull repair candanewell Original Mariah Talk 5 05-09-2010 08:32 PM
    Need help with hull ID mjhinno Introductions 9 10-05-2009 10:31 PM
    Hull Cleaning andyc General Maintenance 5 10-01-2009 09:38 PM
    There are 359 users
